alaric28
Hi there! im planning to setup my first home theater system and the bose cube speaker impressed me. but why thie site say no to Bose?
Which speaker should you buy? The ones you like the best, of course. Thank you; I'll be here all week, and don't forget to tip your waitressesalaric28 said:Thanks for all the comment, now i understand why my brother in law also told me dont go for bose its just a brand![]()
about the speaker, im still confused about the differences of big tall speaker and the satelite speaker. which is better? i knw satelite speaker look cool but the quality of the sound is better or equal to a big tall speaker? what speaker should i buy?
Not true. Even someone who enjoys the product they bought will feel ripped off when they hear a $300 system that sounds every bit as good. Its called buying shielded computer cubes from Future shop and plugging them into a $30 decoder from Walmart for your inputs and getting *better* sound than Bose.Resident Loser said:...all these things mean zip-o to the many people who own and enjoy their equipment...
Aside from being picky (and that's good if you're an audiophile), I'd like to point out that *almost any piece of wire that fits* will connect your speakers to any receiver on the market. And almost any wire that fits will connect any component you have to that receiver. The inputs are even labelled, last I checked, on every brand out there. There's nothing easier about the Bose way, its often less intimidating because it has *fewer* options. So buy a really cheap receiver.Resident Loser said:prices...simple plug'n'play vs. mix-and-match footwork...Do I have all the right cables? How do I set this up? Gee, the salesman told me this would work, so why doesn't it? The ol' cost vs. value argument is a hard nut to crack.
