warnerwh said:
Something nobody has yet brought up: With a set of full range speakers and a sub or two you can get a better in room frequency response. I run my full range speakers with a sub. These speakers are 6k a pair and will definitely go low but with the sub in the corner my room modes are less pronounced. The sub is crossed at 45hz and speakers are run full range. And yes there's much more music information down below there than most people might think. This allows me to pull out my mains for best imaging and the least amount of room related problems and get a better bass response. In other words, having the bass being reproduced at different points in the room you can get a smoother response. I'm pretty sure there's an article on this site explaing room modes if you don't understand them. Very good reading and necessary to get the best your system is capable of.
.....absolutely, Warnerwh, I would let the mains eat to the bottom, AS LONG, as nothing got offensive in the lows of the mains....there's some guys out there who aren't able to move up at this time, that have mains that are whompy and "slightly distorted" at the bottom and the mids seem weak....listen, try this, I will buy any equipment damaged.....I say again, if the low end of your mains is, let's say, heavy, and it overshadows the lower and mid-mids, using receiver or slave amp, for the 50th time--less strain is put on the amp section pushing it, "cross", the speaker wires, and behold....cranked.....you'll have your sub/s to keep you warm if you worry about losing too much bass....but you're only losing mud....reverse inductance path with the same crossover points is all that happens with what's going through the elements.....
.....hey, maybe your speakers will sound horrible crossed, I don't know, but I'll tell you this, mine sure didn't.....won't hurt a thing to leave them crossed for the next 50 years, neithern.....you may need to cut the highs at about whatever smooths the raspy, if you have raspy, I did, some of you won't....ladders, to bed....mule......
