Which front speakers match B&W HTM3S center?
Pablo2k
Pablo2k
Hi!
I traded some stuff for a beautiful condition Bowers & Wilkins HTM3S with stand.
It replaced my HTM61 which I never really liked.
I have 863 s1 in front and 864 s1 in tears.
I think there are 804N and 804S out there.
Which one matches the tweeters on my HTM3s?
I like to upgrade my mains.
Thank you!
Pablo2k
Pablo2k
Oh boy, I think that thia center matches 804S and not 804N? If so, 804S are more than double than the older N. I can barely afford the N version...
I wonder if this was a bad move... I just really like how the HTM3s looked, and that I also hated my HTM61.
I never use the center speaker when I listen to music, I only use it for movies.
I don’t hear the speakers to be unbalanced when all 3 are on during a movie.
Would CM10 and 804n sound closer to this Htm3s?
Or am I just wasting money and might as well keep the 683?
Thanks again.
shadyJ
Speaker of the House
Staff member
Looks like the 804S is the matching speaker for the HTM3s center.
I think that if you get anything less the the 800 D3, all of your friends and family will consider you a failure.
You know what you have to do...
2
2channel lover
Hi!
Thank you!
Just about any of the floorstanding 800 series speakers will a pretty good match for the HTM3, but ShadyJ was correct...the 804N and probably the 804S...I'd use it with a pr of 803s as well but if you're running subs, I wouldn't buy the 803. 804N vs 804S...I have the last gen 804M, the N is the 1st gen Nautilus series after mine. I'm thinking they have the same midrange/woofer drivers...maybe, but I don't think they changed the tweeter until the diamond series.
Johnny2Bad
Johnny2Bad
In my experience, established loudspeaker brands follow a consistent sound signature, so any B&W model mains would probably work well. Centre channel audio is more focused on midrange, an area that most speakers do well at, so really I would suggest choosing the mains you can justify cost-wise vs sound quality. Your Centre Channel should mate well with any B&W mains, tonally.
