lovinthehd Audioholic Jedi Sep 11, 2012 44,890 0 113 Oakridge, OR Jan 8, 2022 #21 Okay, about same as my bedroom. I built a pair of sealed 12" subs for it. Used a "car" sub driver, Infinity 1262W....
Z Zerofox0070 Enthusiast Jan 6, 2022 20 0 1 53 Jan 8, 2022 #22 lovinthehd said: Okay, about same as my bedroom. I built a pair of sealed 12" subs for it. Used a "car" sub driver, Infinity 1262W.... Click to expand... Whoah nice one mate a I bet they go deep and have earth shaking output not only because of watts because it’s a bedroom like mine and that will have serious chest thumping output in that room and you have dual for smoother response and more accurate output
lovinthehd Audioholic Jedi Sep 11, 2012 44,890 0 113 Oakridge, OR Jan 8, 2022 #23 Zerofox0070 said: Whoah nice one mate a I bet they go deep and have earth shaking output not only because of watts because it’s a bedroom like mine and that will have serious chest thumping output in that room and you have dual for smoother response and more accurate output Click to expand... Works well in that size room, altho in general that driver works okay in larger rooms as well. One of the guys here had four of 'em in his main theater IIRC. They're fairly sensitive and I have a decent amp for them and the eq they need. Not all "car" drivers will do as well in larger rooms like a typical in-home room though (vs a car's cabin). Might be an alternative to you to just build your own?
Z Zerofox0070 Enthusiast Jan 6, 2022 20 0 1 53 Jan 8, 2022 #24 Hmm interesting at least with building your own you have more variety and selection for enclosure amp driver etc and possibly build a monster sub that you run as duals that will have more smoother response more power output deepness and tightness than dual svs pb16 ultra and 4 klipsch r115sw’s I will invest in this as I wouldn’t mind more output than dual svs pb 16 ultras
lovinthehd Audioholic Jedi Sep 11, 2012 44,890 0 113 Oakridge, OR Jan 8, 2022 #25 Depends what drivers you can get. Usually you can get a single amp to drive both to help out on the costs. Your wood working and tools can handle it? You'd be satisfied with your own finish? I'd say go for it!
