I opened up the entire bottom half of the wall from left to right.. Repainted and reinstalled my new Free Range Speakers.
The sub is currently in the wall to see if it's 'good enough' while I work on a overall better situation.
However now that I've opened up most of that wall, would you guys still recommend putting the sub.. elsewhere? Behind, in-front, close to the couch?
If behind the fabric in the wall is ok, should I also open the ceiling above the sub? see pics.
That overall better situation will be to order a very long cable and try to pull it inside the wall along a fur-down. after that I'll have more placement options.
Also, once this crazy shutdown is over and if both me and my wife are still working. I'll look at getting a 2nd sub.
Also 80% of the reason I put the foam there was because I had a lot of it and nothing to do with it. I can remove it super easy. I don't think it's really doing anything positive other then looks kinda cool.
