Mid-Level Receiver w/Pre-Outs...
Deathwish238 said:
I don't know if this is possible or not...but what pre-pro and amps should I look at with a $1k budget? Thanks in advance.
One consideration may be a decent 3 or 5 channel amp in conjunction with using a mid-level AV receiver with pre-outs. Some receivers that come to mind are the
Denon 2805,
Yamaha RX-V2500,
Onkyo 703 and
Harman Kardon 435.
Most of these mentioned (if not all) are the previous generation receivers, so you likely could find a decent deal on them and still be mostly up to date w/the options (less newer HDMI, XM radio, iPod compatibility features, etc.).
These, coupled with a good outboard amp for (at least) your front sound stage, should offer excellent 2 channel & multichannel music listening as well as excellent home theater/movie soundtrack performance. One reason this may be a bit more appealing is if you decide to step up to a stand-alone pre/pro, you'll be able to get a decent return on the receiver if you decide to sell it.
In order to keep the price down on the amp side, consider previously owned (Audiogon, eBay, etc.). Amps are one of few electronic components that hold their value well. A two channel amp that's gotten pretty decent press here and other HT forums is the
Behringer A500. Three of these, a Yamaha RX-V2500 from uBid as mentioned above would give you a very nice setup for right around $1000... TD
