C cameron paterson Audioholic Chief Mar 7, 2018 907 0 18 48 Aug 1, 2021 #1 What does "are you using a slotted port" mean on this website? Port Length Calculator Port length Calculator for sub woofer box design. www.mobileinformationlabs.com
ryanosaur Audioholic Overlord Sep 14, 2018 11,686 0 113 Aug 1, 2021 #2 Are you designing a port that is a slot port? Tubes with or without flared ends? Those are the two basic options. If you are unfamiliar with slot ports: That's a slot port.
C cameron paterson Audioholic Chief Mar 7, 2018 907 0 18 48 Aug 1, 2021 #3 Why on this website when I plug in 7.5ft3 with a port of 3" x 16" tuned at 20hz does it say the length of the port is 37"? https://www.the12volt.com/caraudio/boxcalcs.asp And on this website when i plug in a square port at 7.5ft3 with a port of 3" x 16" tuned at 20hz it says 29" with a slotted port. And 37" without a slotted port? Port Length Calculator Port length Calculator for sub woofer box design. www.mobileinformationlabs.com
ryanosaur Audioholic Overlord Sep 14, 2018 11,686 0 113 Aug 1, 2021 #5 I don’t trust online calculators. Your numbers above don't make sense. Is your cabinet volume supposed to be 7.5cu.ft? Do you know the volume of the port you need to achieve the tuning you are after? What are the actual box dimensions for your 7.5cu.ft internal volume?
TLS Guy Audioholic Jedi Oct 30, 2007 27,293 0 113 79 Eagan MN Aug 1, 2021 #6 cameron paterson said: Which one do I use? Click to expand... 3" X 16" are the dimensions of the opening on the front of the sub below the driver. 37" is the length of the port. It is skating close to the wind to construct a port that long. A port that long, because the port resonance will be clearly audible and horrible if you excite it, as the port is an open organ pipe. The fundamental frequency of the port will be 177 Hz. If you cross at 80 Hz there still will be enough power to excite the resonance. If you cross at 60 Hz you will get away with it. When you get ports that long, then you are getting to territory, where you need to tune with an ABR or two rather than a port. An ABR is an assistant bass radiator.
C cameron paterson Audioholic Chief Mar 7, 2018 907 0 18 48 Aug 2, 2021 #7 Yes box needs to be 7.5ft3 after all displacements tuned at 20hz. Could I make the port smaller than 3" x 16"? I have an 18" in a 6.8ft3 box tuned at 20hz with a 3" x 16" and even at 20hz there is absolutely no chuffing. Could I do 3" x 13"? Don't the SVS PB16 only have 3, 3.5" ports? Thats less port area than 3" x 13". Last edited: Aug 2, 2021
lovinthehd Audioholic Jedi Sep 11, 2012 44,872 0 113 Oakridge, OR Aug 2, 2021 #8 I'd use better modeling software than that site offers. Winisd or bass box pro etc.
