Buckeyefan 1 said:
If the center channel is still too low, then manually boost the dB rating. I have mine set on +7.
WOW, thats like almost maxed out.
Mine is set at +1.0 to +2.5 depending on movie.
My other specs are
L +0.5
R +0.5
C +1.0 - +2.5 DEPENDING ON MOVIE
RS +1.0
LS +1.0
SB +0.5
SW -9.0 TO -7.0 DEPENDING ON MOVIE (sub amp turned up just over half way)
Pioneer VSX-1015tx
Fluance AV-HTB Fronts
Fluance AV-HTB Center used for SB (Have Cadence XC-9 coming)
SDAT Center + SDAT Fronts used as L+R Surrounds (Have Bic HT-63 & HT-65 coming)
NeuNeo HVD-2081 used with 3' Optical
All the stuff that is coming will be here on Tues. And will repost with those.
Both the Bic sets and the Cadence are extremely efficient Bics at 96db and the Cadence for the back surround at 94db.
So I am assuming that all the settings will change dramastically.
Trying to find another XC-9 to make it a 7.1 setup.
