I'll put quotation marks around your comments, so I can respond to each, separately.
"It’s interesting to read all these negative comments about a product that nobody in this thread has personally tested in their music or video system. All these people honestly think they know a product, and how it performs without ever listening because they can’t understand why it should work. Well then none of your opinions really matter..."
If the results of your product can't be measured, any increase/decrease in performance must be subjective. That's usually called an 'opinion'. This link has some definitions of the word:
http://dictionary.reference.com/browse/opinion?&qsrc=
"The Weizhi PRS6 is not a powerline conditioner, it's not a filter. In fact it has no electronic parts inside. This product works by using proper materials in the right places."
Assuming the receptacles aren't on the outside of the case, they're in the right places, even if the case material was wood, plastic, etc. "Proper materials"- hmmm. Who decided which materials are proper?
"If you have a big investment in your Audio or Home Theater system, then you know clean power is very important to achieve great performance from your gear. Most people use powerline filters, transformers, regulators and surge protectors of various brands to clean their power. Many of these products are very complex with lots of parts being used. Some of these do work quite well, but the problem is they are not invisible. Filters & conditioners leave their signature on the sound, while transformers tend to compress dynamics, and don’t even bother investing in a high end system if you’re going to plug it into a surge protector."
Clean power IS important but I'd like to see where this is actually available. 'Clean' would have to include stable voltage as one of its characteristics, right? Unless someone has their own power source, I don't know of anyone on the nation's power grid who has access to truly clean power.
"The Weizhi PRS6 will not soften or roll off the high frequencies, it will not compress the dynamics when the volume is turned up, it will not alter the tone of instruments or vocals, it will not mess up the delicate timing and pace of the music, and it will not add or take away anything from the original music or video source. What it will do is allow the power to pass through without the line noise attached, Simple & Pure."
You just claimed that it removes line noise. Show this. If you can't, your product doesn't work.
Wait, what? How would a power conditioner that works with only the power supply input possibly affect the "delicate timing and pace of the music" if the signal doesn't pass through it? A synchronous motor uses the 60Hz waveform to maintain its speed without being affected by line voltage fluctuations and that was the reason a lot of turntable manufacturers used them. DC motors are less prone to transmitting vibrations to the platter (especially belt driven) but they are susceptible to speed changes with voltage variations. Digital music has a clock frequency- are you claiming that these timing and pace variations are so large that people can hear them when your product has been removed?
"The Weizhi PRS6 was designed to eliminate the noise from your mains without filtering it. You see it’s best to keep the signal path simple and use better materials, than to pass the signal through hundreds of parts or miles of transformer wire. Clean mains power is the foundation of your system, and without it your (
you're- it's a contraction that means 'you are') amplifying grunge."
Again, you claim something but use your own definition of words to make your claims. If it eliminates noise, what's the difference between using 'eliminates' and 'filters'? Where does the noise go?
It's good to keep the signal path simple, using better materials
when they make a demonstrable difference but when the electric company sends power to us through a grid that contains many transformers at nearby poles and sub-stations, I fail to see how you can claim that anyone is getting clean power.
"Most of my dealers offer a 30 day money back on this product. The quality of the power cord you use will not effect this units performance, instead you will hear exactly how the power cord sounds. So choose a power cord which sounds best to you. Since the unit is wired with silver I do recommend silver power cords for proper matching, but I have also heard excellent results with good copper cords."
Again, how does this remove the "sound" of the power grid?  Oh, right- this product eliminates it without filtering.
"We also have 3 online reviews of this product which can be seen on my website. More reviews are in the works and will be online soon."
Why would you post bad reviews on your website?
We all know the human mind can ignore or emphasize what the sensory organs receive. When a listener wants to hear something, usually because
they were told what they would hear, they often do. When the device is expensive, they may want to justify the expense by claiming that they hear the difference. If the investment is time & effort or money, positive results are a good thing.
You're asking people to accept the claims on faith. Do you sell Speaker Bullets, too?
http://www.bybeetech.com/FeaturedProducts.asp
