You can not mount them upside down. Speakers are pretty heavy. If you are going to use a screw, then you had better find a stud, if you don't want to repair sheet rock. Those swivel mounting brackets are useless.
When I did an installation for some one and they wanted wall mounted surrounds, I made aluminum brackets from 1" angle stock. Screwed them to the 4 X 4 s and screwed the speakers to the brackets top and bottom.
The other thing you can do is build a shelf for it screwed to the 4 x 4s. That is probably the neatest and is very safe. Like in the picture below.
Speakers are heavy and you have to be careful wall mounting them.
[/QUOTE
