UTTT...OHHHH...I bought another BOSE system...
Adam
Adam
The help on Windows Media Player 10 does show info on converting files. I can't figure out the specifics, but WMP11 might be able to do it.
ParadigmDawg
ParadigmDawg
Man, I cant figure it out.
Adam
Adam
I'm with you, brother. It's not straightforward in WMP, as far as I can tell. I'm at work, though, so I can't devote too much time to looking through that.
As for iTunes, I can help you with that - but it would be later tonight after I get home because I don't have it on my computer at work. I'm sure that someone else here can help you out if you need it sooner.
Adam
ParadigmDawg
ParadigmDawg
I try not to use Itunes as I had a run in with them in the past where I lost all my music and they basically told me tough crap. I use WAV files on my external HD and play through my HT system or just stream wireLess to my PS3. Now I am trying to go backwards just so I can use the FC in my car, what a messd up world.
Adam
Adam
Adam
Dude, just use iTunes to do your bidding then throw it aside! :) No need to use it as your main program.
Adam
Adam
Ok, I downloaded it and it is automatically copying my songs over to ITunes. What do I need to do now?
Say your prayers, sucker, because I just fooled you into downloading something that will take over your computer. You've been Apple-fied! :D
Just kidding (of course). I won't be able to go through the steps with you in detail until I get home (probably in about four hours). I think that you need to change the file type for ripping in the options (maybe called preferences) to what you want (MP3, right?). Then, you can select the songs in the library list, probably right click, and then see a choice for converting them.
Let me know if you get it. I'm more than happy to go step by step once I get home.
ParadigmDawg
ParadigmDawg
Seems to be converting. Now I wonder how to get 46 GB of music on a 2 GB flash Card....
Adam
Adam
Glad that it worked out for you, Greg. Enjoy your tunes in your new vehicle!
