Slow Down A Bit.
Hi,before you go any further understand this,the gear your father has was top of the line high end hifi gear in its day & is still worth several thousand dollars,you should also understand that all the gear your thinking about replacing the reciever with is worthless junk junk in comparison,kinda like replacing the engine in a porsche with a fiat engine
Forget about the T AMP, i can tell you that it is without a doubt a hyped up peice of junk not worth the $2 it costs to make it,i own that amp & even with super efficient klipsch corner horns it was a useless amp that is incapable of meeting any kind of demand that is put on it,except maybe some frank sinatra or barbara striesand at low volume but anything else it will fall flat on its face,dont fall for all the hyped up reviews on this T AMP it is junk
If your mcintosh reciever is not working now but it was working properly when taken out of service then it will be something very simple & easy to correct,if your mcintosh reciever is either model # MAC 1500 or MAC 1700 then its a hybrid unit meaning that it uses a combonation of tubes & solid state,the MAC 1500 has a solid state preamp section with a tube amplifier & tube tuner section while the model MAC 1700 has solid state preamp & amplifier with a tube tuner section,all other mcintosh recievers were made strictly solid state,no tubes,tubes for these recievers can be bought for very little cash & installed in less than 10 minutes,please post the model number of your reciever as i may have a replacement stock mcintosh branded tube that will get you back up & running if you have a burnt tube.
I mean no offense but are you 100% sure that you had everything hooked up properly & had the correct source selected on the reciever,also some of the older model mcintosh recievers had switching on the front panel like tape monitor or tape to tape dubbing that if not in the proper positions will not allow you to hear any sound,some also have several different sets of speaker inputs that once again if not hooked up properly & have the right selection on the front panel will not produce sound,i'd be willing to bet that there is nothing wrong with the mac reciever & the problem lie's with either hook up,source selection or a combination of both because these units rarely(if ever) stop working.
Before going any further make a quick phone call to Mcintosh labs & talk to their tech rep,1-800-538-6576 & ask for Chuck Hinton,he will be able to walk you through set up & help you trouble shoot anything like a faulty tube or blown fuse.
You mentioned using an external amplifier with the preamp section within the reciever,think about this,if you go out & buy a $200 mass market amplifier the same day you buy it the amp will lose value & only continue to do so,these type's of amplifiers only lose value to the point if something goes wrong after the warrenty is gone it becomes too costly to repair & becomes throw away gear,on the other hand if you either take the time to assure proper set up or spend a few bucks on repairing the mac unit you will have a peice of gear that is & will continue to be worth something many years down the road & is allready a sought after collectors item that even in a state of disrepair is worth more than any of the amps or recievers mentioned in this thread.
Worst case scenario with your reciever is it will need a total retube but it will still cost less than a mass market external amp or reciever,less than $150 to retube the entire reciever.
