I am planning to buy PIONEER VSX-1020 from USA
I heard that the only difference is the voltage, but it can easily be solved with a voltage converter
my question: does this receiver passthrough PAL video, or does is upscale PAL video
I checked the video processor and it is the same for both europea and US,
on the both manule it states that
• The signal input resolutions that can be converted from the component video input for the HDMI output are 480i/
576i, 480p/576p, 720p and 1080i
do you thibk that US version of this receiver will work in Europea, or those are same receivers
thx in advance
