S_singh
I’m getting a great open box/excellent condition deal on a Denon x6700h for $1300, would that be ideal?My choice would be the A6 or A8 if they are within the budget.![]()
Could always try.I’m getting a great open box/excellent condition deal on a Denon x6700h for $1300, would that be ideal?
If you felt the Cinema 50 was a lateral move, then the A4A wouldn't make a difference. The A6A should be able to do it. The AVR-X6700H is quite powerful too so it may work as well. If not, the you can add a 3 channel power amp but not the Emotiva Bass X, need something more powerful.Was considering the A6A or A8A, would I miss much if I chose the A4A over the other 2?
Was also looking into outlaw 7000 would that be the same thing as the Emotiva Bass X?If you felt the Cinema 50 was a lateral move, then the A4A wouldn't make a difference. The A6A should be able to do it. The AVR-X6700H is quite powerful too so it may work as well. If not, the you can add a 3 channel power amp but not the Emotiva Bass X, need something more powerful.
The Outlaw likely have a larger power supply, but I am thinking of the Hypex based class D amps, such as the NC252MP based ones.Was also looking into outlaw 7000 would that be the same thing as the Emotiva Bass X?
Try the ATI-built Outlaw amps for the more significant power.Was also looking into outlaw 7000 would that be the same thing as the Emotiva Bass X?
