Under $600 Receiver Advice: Denon vs Onkyo
I have the denon avr-x1300w. All of a sudden, while listening to the device the volume keeps turning down to 0 regularly. Someone please help!!!!!!!!!!!!
Try a soft reset (unplugging it for a while). If that doesn't do it then a full microprocessor/factory reset per your manual.
Digeneral
Thanks for the advice. Let's see if that works. Yes, my setting is 0-99
tyhjaarpa
tyhjaarpa
Should make your own topic and you will get answers better to your problem and keep other topics clean to read.
The Denon X3000 series is a $1,000 AVR. So for under $600, you cannot do any better.
I have used the Denon X3000-series AVR to power speakers costing $9K - $15K/pair. Highly recommend it.
Also spend $20 on dual AC Infinity 120mm USB fans to cool the top of any AVR you buy. Have the fans blow upward.
https://www.amazon.com/AC-Infinity-MULTIFAN-Receiver-Playstation/dp/B00JLV4BWC/ref=sr_1_1?ie=UTF8&qid=1518986460&sr=8-1&keywords=ac+infinity+120mm+dual
LOL I clicked on your link and ordered the fan. The gigantic fan showed up the next day and now I have to figure out what to do with it. In the mean time I am going to order the smaller one that I thought I was getting. They made so many models, even the same size ones have different model numbers.
https://www.amazon.ca/AC-Infinity-MULTIFAN-Receiver-Playstation/dp/B00G059G86/ref=sr_1_8/142-9106839-8580960?ie=UTF8&qid=1519247874&sr=8-8&keywords=ac+infinity+fan
I only use the 120mm fans.
The 120mm fans don't fit your setup? Why not? I have 2 of the 120mm fans atop each AVR.
The 80mm fans are too small for me. :D
For my AV8801 there is no enough headroom, for the MM8003 there is headroom for it to lay flat, but I want it to blow from the back so still not enough headroom to stand it up. I just order the 80 mm and will try to use the 120 mm for my Oppo HA-1 that is crazy hot as it is class A. I don't need a lot of CFM because I remove the front doors so the front is wide open.
I see. So you are mainly blowing air from the back to the front (fans upright).
I am just blowing air upward (fans flat), which is enough to keep my AVRs extremely cool.
