i feel like i do whatever wmax says
when he said the A500 was the bomb, i got 4 of those.
then the EP2500, i got two of those.
then the yammy, i could only afford the P2500S
i'd say i really got my bang for the bucks.
-o-o-o-o-o-
having a "cheap" 2ohm stable amp in the EP2500 is spectacular.
expecting ANY amp to run 2 ohm stereo (same as 4ohm bridged) full bore is too much
i'm thinking a super cooled/ventilated version of the EP2500 can do it.
-o-o-o-o
i think the easier/better solution is to get another of the same sub. run each off each channel. should be about 3db gain IIRC, and will give the amp a lighter load. you also gain better bass response.
