mike c said:
i asked the HK guy to tell me WHY his 55w AVR335 can trump a 120w yam 1500
he said two words ... high current
so i promptly asked the yam guy, he said, yams are ALSO high current
SO, lets break down the choice to this question ... which has MORE power? (which will give me so loud that my head will explode ... but w/o clipping and still with clarity ... you know) [i suppose both can do the same job of creating 7.1 surround, i might forget and miss the point of mostly HT use]
the 335 costs php 37000 and the 1500 php 34000 (divide by 56 to get USD)
53USD price diff.
I almost bought a HKAVR7200 myself and I really like their receivers, but this high current thing is blown way out of proportion. How high the current goes depends on how loud you play your music and how low the impedance of the speakers dip down to. I have read something like, "its current that gets you real power" or something like that, simply not true! Sure, the power supply must have the current capacity, but the currents don't just flow out high regardless of the load impedance and the input signal. Most mid price receivers have power supply that can deliver reasonably high current when call upon, for a short duration.
The fact is Power=VoltageXCurrentXPower Factor (phase angle between the voltage and current), or =VoltageXVoltage/Resistance (the real term of the complex impedance), or =CurrentXCurrentXRsistance. All these are variations of the same power formula. Search the web, or refer to any basic electricity text books you will find out how these formula are derived.
Again, I like HK receivers a lot, but whether the 335 has more power than the RX-V1500, it really depends. The 335 may have a larger power supply and more all channel driven power, but I would bet the 1500 has more powerful amps so it may have more power (and yes, likely higher current) for 2 channel material. Try search for lab test reports on the web, you may get lucky and find some.
Following are quotes from Nov 2004 What Hi*Fi Sound and Vision magazine, here's a little bit of what they said in their reviews of the HKAVR630 and Yamaha RX-V1500.
HKAVR630 (overall rating: 4 stars) ........."the AVR630 lacks the muscle to elevate special-effects laden scenes-after only the first few explosions in Saving Private Ryan, the receiver loses its poise. The midrange is equally subdued an inexpressive. Musically it offers rhythmic timing and reasonable detail, but once again it struggles at high volumes. At lower levels it sounds good, with the Logic 7 processing mode being one of the most effective surround-creation systems."
RX-V1500 (overall rating: 5 stars).. ...."It packs a powerful punch, with plenty of solid weight adding emphasis to explosive film sounds. Scenes from Behind Enemy Lines had our review room literally shaking. While some receivers fluster in the face of high-powered special effects, the Yamaha keeps a firm grip of low-frequencies and maintains its composure throughout..............Music, especially multi-channel tracks, are evenly balanced and rhythmically timed, though a slice of brightness is served up at the high end. Using Pure Direct mode for stereo playback produces a detailed and dynamic presentation that competes with any receiver in this class"............
