Now Brian, you shouldn't be randomly quoting numbers that you have no backing for. Okay, that aside, I use an old Yamaha CR-1020 to power my BIC Venturi Bookshelves. I think it's rated for lik 70wpc, and this thing CRANKS. At volumes where I literally need hearing protection to be in the same room (room is about 20x16x7). At these damaging levels, I'm only hitting 50 watt PEAKS (according to the VU meters on the receiver). Now granted, these speakers have a 90dB efficiency, but seeing how I can push 50 watt peaks and need hearing protection, you should be fine.
