The Difference Between Bi-amping and Bi-wiring
Swerd
Swerd
My earlier comments were written assuming you had less knowledge about electronics than I now understand you do have. I guessed wrong and wasn't trying to slight you.
What about the voltage limit of the amp? E.g.: there is -+20V PSU. If you have an 50Hz sine wave with the maximum output amplitude (20Vpp) and you want to add a 10kHz 2Vpp signal on it, the 10kHz signal will be cut and limited because of the supply voltage limit. If you filter out the high amplitude 50Hz before the amp, you will not have this problem on high frequencies. So in this case it makes sense to use the filter before the amp. What do you think?
You are worrying about voltage clipping in very small amplifiers while ignoring the larger problem you have with mid grade speakers (a charitable description of some MA Bronze speakers I once heard years ago). They have what is likely to be much higher distortion and poorer sound quality than any improvements you might obtain by the various contortions of bi-amping with small class A amps.
You will have greater improvements to sound quality if you focus on acoustic waves coming from speakers than if you focus on electronic waves going into them.
Barnabas Puskas
The idea that bi-amping lowers IM distortion (intermodulation), or improves sound by separating a woofer's back EMF from the tweeter, is old and has been debunked.
Removing or disconnecting your speakers' crossover networks will also void the warranty.
Depending on how these additional filters are designed, this, at best, will accomplish nothing. At worst, these additional filters will have a negative impact on the function of the speakers' crossover filters. This is a solution for a non-existent problem.
Thank you for your reply. Can you give me an explanation for the concept that lower bandwidth why not cause less intermodulation? When I was young it was teached that less spectrum lines have less intermodulation combination. E.g.: If you have two sine waves only (2 spectrum lines) you can have result A+B and A-B as a combination frequency. If you have 3 lines, you can have A+B, A+C, C+A, A+B+C, A+B-C,... much more. In narrower bandwidth you have less spectrum lines, which produce less combination frequency. This is the same in DWDM technology in optics (I am a DWDM specialist). You can give technical answer. I am an electrical engineer. :)
Regarding the last two parts I agree. Thanks again!
Swerd
Swerd
I can only repeat what I said before. Sound quality is more about acoustics and the wave behavior of the rather long wavelengths involved with 20 to 20,000 Hz, compared to the much shorter wavelengths involved in other aspects of electronics, or optics. I'm not an EE, so I'll stop and wait for one of several EEs who frequent here to take the ball. @PENG, where are you?
I do recognize and appreciate your straight forward and polite posts on the highly controversial subject of bi-amping :). Many times we are on the receiving end of heated attacks from hard core Cool-Aid imbibers, or mock attacks from trolls. You clearly do not seem to be one of them.
Barnabas Puskas
No problem. I did not know either if electrical engineers are here or just golden-ear guys. :) But I am happy that I can really have discussion here with technical guys. Yes you got the true that probably not the amplifier is the weakest part of my system. I tried these speakers with A/B class amp (e.g.: Texas integrated gainclone), but it sounded differently (worse) with that. Maybe I should try with another type of A/B. Anyway Bronze 6 is not bad. Ok, not high-end but now they use the old Silver drivers in Bronze, which was a significant improvement in this price category. Anyway the biggest problematic part in my system is the source of the music. It is hard to find a dynamic compression free music nowadays thanks to the loudness war. But this is another topic.
Swerd
Swerd
There are several regulars who post here who are EEs or at least have enough background to talk like an EE. I am smart enough to know when to keep my mouth shut :D.
We tend to frown on 'golden ears' or those who cannot back up their extreme opinions with some supporting evidence.
There are at least one or two here who have built their own amps or amp kits.
True, I agree.
If I have any expertise at all, its about speaker designs and what actually produces better sound quality. Or what features produce audible problems. More often than not, it's poor crossover design. I can think of several commercial speakers which allow too much woofer break up noise to get by. If I remember correctly from more than 10 years ago, the Monitor Audio Silver 2-way tower speakers I heard suffered from an aggressively forward sound. At first it sounded like the speakers added great detail. But it led to an irritating edge in the upper mid range. I never listened longer to know if that led to the dreaded 'listener's fatigue'. It might have been due to inadequately filtered high frequency resonance or noise coming from the metal alloy woofers. As you can see, I'm a speaker guy, not an amp guy :D.
Nice analogy and it is true if we speak about power. Of course the amplifier cannot push any power on the high impedance part of the load (that frequency range which is out of the woofer / tweeter range). But a question? What about the voltage limit of the amp? E.g.: there is -+20V PSU. If you have an 50Hz sine wave with the maximum output amplitude (20Vpp) and you want to add a 10kHz 2Vpp signal on it, the 10kHz signal will be cut and limited because of the supply voltage limit. If you filter out the high amplitude 50Hz before the amp, you will not have this problem on high frequencies. So in this case it makes sense to use the filter before the amp. What do you think?
Note: I use an own built class A amp with limited power.
That seems right in theory. I am not sure if you will end up with a net gain in sound quality because now you are introducing an active filter ahead of the power amp, and that itself could have negative effects depending on how it is done. I think overlapping the bands is a good idea conceptually. Sounds like a fun R&D project. The more typical response to this kind of questions don't seem to apply here because you are trying to biamp using a very low power amp to drive the tweeters and a beefier amp for the woofers.
Thanks for your useful answer. Yes, the other thing why I begun to think about biamping is the power sharing. At this moment I use a pure class A amplifier (a John Linsley Hood one) to drive this speakers, but it has quite a low output power (8-10W RMS max.) So I have two ways now:
- use biamping with 2 JLH amp / channel or one A/B class for LF and one pure class A for HF
- build a bigger amplifier: here the problem is that it is not easy to build high power class A amp because of the cooling and high power consumption problem
Note: I prefer class A only based on my good experience.
Then your answer if you insist on class A is a Quad current dumping amp. That is Peter Walkers brilliant invention.
The concept, is a class A/B amp, that actually does not have to be outstanding. This is the dumper. Then there is a very good class A amp that feeds a feed forward error correction. This gives pure class A performance. It can be shown mathematically and in practice that the performance is entirely the spec. of the class A amp.
These amps run very cool.
3 KW of class A audio power that powers my studio/AV room. That is a bank of seven Quad 909 power amps.
I think the main advantage of bi-amping is not to amplify the whole spectrum reducing the intermodulate distorsion with this method.
I have to think about this, but on surface I doubt that is the case because instead of have all the IMD frequencies generated by one amplifier, you simply have them generated by two amplifiers in the bi-amp scenario. So any reduction in % IMD will depend on the qualities of the amp/amps, not on whether you use one amp or two/bi-amp. That is you still have the IMD for the full spectrum.
IMD is generally not a problem for good quality and relatively affordable amps made by reputable manufacturers.
Well then I guess not much has changed, I installed a 7.1 MA system based on the Silver 8 and the Marantz SR7009 about a year ago. My initial impression of their sound and my updated impression in a recent visit remain the same, that they are a little bright and overly forward. To give them some benefits of doubt though, that room is not particularly well damped and too big for the AVR. So I am sure there is room to improve, but they sound great to the owners so there is nothing I can do about it.:D
DigitalD
He is talking about back EMF into the amp. Not really an issue. Personally I do like passive bi-amping in some cases. Back in the day I used to biamp with my Denon 5805 for my front towers. That receiver had a ton of reserve and it helped to drive my towers better than the single amp connection. However, I could have achieved the same results simply using a higher power external amp in a single wire connection.
Would Bi-Amping my Klipsch RF7IIIs with an Outlaw Model 7000x receive any benefit? I feel like I am not getting much bass and I am upgrading from Polk Satellite speakers. Maybe the speakers aren’t broken in yet?
Irvrobinson
Irvrobinson
Speaker break-in is a myth. With those speakers and an Outlaw 7000x it is unlikely you will receive any benefit all, unless you have a huge room and listen to very bass-heavy music at high volumes.
DigitalD
So I basically need a higher powered amp to see a benefit/increased bass?
Irvrobinson
Irvrobinson
No. I don't believe a higher power amplifier will give you better bass. More likely you either need different placement of the RF7IIIs to mitigate so-called "suck-outs" in the listening seat frequency response, or you need to add one or more subwoofers, placed for smoothest bass response.
Kvn_Walker
Kvn_Walker
My speakers are bi-wired. Why? Because I have lots of extra speaker wire and I was bored one afternoon.
Ronald8
With a grain of salt. Each of my Focal 806 speakers only has one set of speakers terminals so classic biwiring is not possible; however, I run four cables from my Marantz receiver terminals to each speaker, i.e., two for (+) two for the (-). A modified biwiring if you will. I notice by doubling the cable connections that there are: 1) More gut punch in the upper bass; 2) Palpable increase in "air" and crispness in the upper midrange where I can feel a slightly charged atmosphere similar to just before a lightning strike; and 3) The resultant sound is more tube-like without the ricotta cheese like grain of SS. Or I could be full of it.
Compared to what? If you KNOW that you are using these "buy wire" cables, then you can hear the difference. The difference was already there before you fired the system up, in your mind. If someone else were to swap those wires out without you seeing them (assuming a cable that is appropriately sized for the speaker load), I would say with fair certainty, you would not hear that difference. Two sets of wires effectively increases the AWG of the wire, but the speaker still only draws the same amount of current.
The reason your speaker has one set of posts is because Focal didn't need them to market these speakers.
I do something similar to what you are doing as well. I bought bulk Canare 4S11, which is a single jacket 4 conductor cable, brining the price down significantly. I terminate both wires into one set of plugs, effectively increasing the AWG. Once those wires are combined into a single connector though, the "magic" of two wires disappears. I do it because I like the heavy duty jacket and it is easy to manage. I cannot say that I have heard any more air than my previous wires which were 10 AWG (8ft runs).
Are you off your meds?
Ronald8
I guessed everyone missed these two phrases: With a grain of salt. Or I could be full of it. No one here has a sense of humor. Well eat it. I quit.
Hey, I laughed. Couldn't take that seriously....
