Warrior,
Thanks for the input. If you don’t mind, I have a couple of follow up questions based on your advice. First, let me say I am questioning your advice, but simply trying to understand why one option is better than another.
1) In going the miniDSP route, should I use the miniDSP, miniDSP HD or miniDSP Balanced?
2) Not sure it makes a difference, but the Mytek input to the Schiit Vidars will be balanced. Should the subs be balanced as well?
3) Is the miniDSP a better crossover than the built in crossovers on the sub amps? The SVS is digital, the HSU is analog.
4) Should one generally avoid using the built in crossover?
5) I assume the use of the Yamaha 801 as a crossover through its existing LFE channel is discouraged due to the crossover being hard set and not configurable on the Yamaha.
Thanks for you help, it is much appreciated.
Mark
1) mDSP or mDSP HD if you have think you might need an optical connection in the future - but you already have a fancy DAC for that. Balanced is intended for car audio.
2) Assuming your sub cables are not 50' long, whichever is convenient for you will be fine.
3) Depending on connection, it is usually best to have a processor/preamp with built in bass management, but for various other setups, the sub's built in crossovers are just fine. mDSP is not 'plug n play'. REW has an automated room measurement system used with a UMIK or similar mic, but results are all over the map, that can upload to mDSP to automatically set the filter values for the subwoofers. Otherwise you need learn how to use a 2x4 - which extends to your next question:
4) The LFE channel that is mixed in to movie sound tracks, is a dedicated channel that usually provides gain to the low frequency effects being passed through it, you're only passing 2CH Stereo. Your objective with the mDSP is to recreate that absent LFE channel by providing gain through the mDSP.
5) The Yamaha is out due to it's lack of preamp outputs so you can use your dedicated amps. Yes it has a subwoofer out, but because it is not in control of the speakers, you'll still have to take measurements and do work to integrate the subs, so why not save it for another room?
I'm leaving town in a few hours... I'll try to check back this weekend.
