SVS Ultra Evolution Pinnacle Review
  • Thread starter Thread starter shadyJ
Save your money, that mini sub ain't gonna fill in anything for the Ultra.
Maybe try just a bit of EQ on the very Ultra's very bottom, just don't push it tooo hard
Agreed, skip the Micro. Your speakers are already very capable in bass, and they don't need a sub unless you are aiming for infrasonic frequencies.
Hello, I used the BK Double Gem subwoofer with the Ultra Evolution Pinnacle, but du to a change in my room I can not use the BK any more.
The only option would be the SVS 3000 Micro, can not go bigger !
Would the Micro be of any use to the Pinnacle as they both do around 23-24Hz ?
Thx....
If you see my measurements above, it would work in your favor to use room correction if it's available to you.
These are designed with a strongly elevated bass region which gives correction software headroom to work without causing extra strain on your amplifier. Out of the box they can pressurize a large room easily and just need tuning.
Forgot I had these Monoprice stands stored away. But they raise the tweeter to ear height perfectly. Wife loves them because it's easy to vacuum under without moving the speakers.
https://www.monoprice.com/product?p_id=39162
I'll have to re-run Dirac and re-measure.
