S shadyJ Speaker of the House Staff member Oct 16, 2006 12,053 0 113 Sep 27, 2023 #2 Both great subs, but I would go with the Monolith. It does have a performance advantage in the low end. But it is much larger and heavier. Reactions: Danzilla31 and sgtkahuna
sgtkahuna Audioholic Jul 11, 2022 117 0 16 35 Sep 27, 2023 #3 shadyJ said: Both great subs, but I would go with the Monolith. It does have a performance advantage in the low end. But it is much larger and heavier. Click to expand... Does the Sony H590 have DSP? I read on YouTube that the SVS is better for people that don’t have a DSP (whatever that is)
William Lemmerhirt Audioholic Overlord Jan 8, 2017 12,005 0 113 52 Sep 27, 2023 #4 It means digital signal processing (dsp) The svs will have three bands of eq available but unless you take frequency response measurements it’s not that helpful since you won’t know what to boost or reduce anyway. I agree with the monolith. Reactions: Danzilla31 and sgtkahuna
lovinthehd Audioholic Jedi Sep 11, 2012 44,872 0 113 Oakridge, OR Sep 27, 2023 #5 FWIW the Sony has their basic DCAC setup program but wouldn't expect it to do much for detailed sub setup (see auto setup on page 26 https://www.sony.com/electronics/su...5cd375e0f9e7103f2b6baa747ed9072/47269061M.pdf ). Might be helpful to use the onboard dsp in a sub, but I'd rather have external dsp/control and capable of multiple subs. Overall I'd still rather have the higher performing sub myself, so another vote for the Monolith. Reactions: sgtkahuna
D Danzilla31 Audioholic Spartan May 17, 2018 7,179 0 113 52 Sep 30, 2023 #6 William Lemmerhirt said: It means digital signal processing (dsp) The svs will have three bands of eq available but unless you take frequency response measurements it’s not that helpful since you won’t know what to boost or reduce anyway. I agree with the monolith. Click to expand... Yeah you have to have REW to know what's going on with EQ bands. Otherwise it's like playing darts blindfolded. Your just throwing changes out there and you don't even know if anything even hit the board
