Sunfire Cinema Grand and Yamaha Aventage/CX-A5100 match??
  • Thread starter Carlos rodriguez
  • Start date
Carlos rodriguez
Ratings
6
#1
Hello, I currently have a Sunfire Cinema Grand amplifier paired with an Ultimate Receiver, with the amp section disabled, basically a TGP III. I am looking to upgrade to HDMI, streaming, newer formats and updated DACS, and I am planning to get an Yamaha Aventage as preamp or a CX-A 5100 processor. I am international and can't return/ship items back, to try different options, I rely on the feedback of more knowledgeable peers.
My question is if Sunfires sound good with modern Yamaha, are they a good match???
My speakers are Klipsch RF-63 surround system, with dual RSW-10D's.
Thank you for you help!!!
Also posted on the Carver site, would really like feedback before taking any steps.
snakeeyes
Ratings
923 1 1
#3
Issues on preout voltages are on the A860 and V781 and 7810. No issues on 1060/2060/3060 or 5100 have been reported.
Carlos rodriguez
Ratings
6
#4
Yep, I saw the issues on the RX-A your are referring to, and steering clear of those. Looking more at the RX-A1060 and up, or the CX-A5100.
My question was more on the sonic match, do you think they "pair" well?
Thank you for your help!
Carlos rodriguez
Ratings
6
#6
I believe that to have synergy between the components that make up a system is important. Judging by your response, for amp/processor matching It is not as important as I first believed.
With Klipsch RF-63 and Sunfire amplifier, would you get the Yamaha?
Maybe I should just get it and see how it goes?
snakeeyes
Ratings
923 1 1
#7
I would go for it. The 5100 review here looked good. Good luck! :)
Ratings
4,959 18 47
#8
One way to find out as they say. I mix my amps among various uses, setups. Don't think ever about matching it other than by making sure the output of the source matches well with the sensitivity/gain of the amp.
