Verdinut's suggestion is similar to my recommendation 5 posts back, but a little more stylish (and expensive) approach...
I went looking for a detailed explanation as the to what the ECO setting really does and found this on another Site (Sounds like Auto may be the way to go...):
Response By Email (NJ Customer Service & Support) (10/11/2016 12:08 PM)
Hi Michael,
When ECO Mode is used, voltage for the amp stage decreases about 1/3 and amplifier stage energy loss decreases about 1/6 compared to ECO Mode being OFF.
It is recommend when using external amplification to leave ECO Mode set to ON. This will reduce power consumption to less than 70W.
When using ECO Mode ON at lower volume levels (under 45 Absolute) power consumption is about 1/2 as compared to leaving ECO Mode OFF. This is useful if using the AVR at night and you do not want to disturb others.
When using ECO Mode Auto, the circuit will control the power supply voltage by a relay. If the volume level is more than 45 Absolute the circuit will cut off. If the volume is less than 45 Absolute the circuit will switch on automatically. If listening at the threshold level (45) you will hear the relay clicking on and off frequently. Voltage for the amp stage does not change here, so power consumption would be the same as normal.
Thank You,
D+M Custom Install
