Yes, I'm an EE with an undergrad in physics. That's exactly what I want to do. :D
monkish54 Audioholic General Dec 6, 2012 #61 Hobbit said: Yes, I'm an EE with an undergrad in physics. Click to expand... That's exactly what I want to do.
M mfontmt Audioholic Intern Dec 6, 2012 #62 Hi guys, now I have my Denon 1613 receiver. I'm connecting speakers and I'm at the subwoofer. On my EMP Tek 1010i sub, which port do I connect my sub cable to. My options are LFE out, LFE in, R, or L
monkish54 Audioholic General Dec 6, 2012 #63 Sorry..misread. On the Subwoofer itself it should be LFE in..
M mfontmt Audioholic Intern Dec 6, 2012 #64 lol, I figured. It made more sense. I guess I should have left out the LFE out. I was really asking about the other three. The manual wasn't very clear. It said to use the L or R for most receivers. Then it goes on to say that the LFE In is for connecting to the subout or LFE output of a receiver. My receiver just says "subwoofer" above the output. Thanks again Monkish. Any advice on crossover freq with my Energy 5.0 Take Classics? I remember reading somewhere that I should just turn it up on the sub all the way. Not sure if this is right.
G Grador Audioholic Field Marshall Dec 6, 2012 #65 mfontmt said: I remember reading somewhere that I should just turn it up on the sub all the way. Not sure if this is right. Click to expand... That is correct, you're going to let the receiver take care of that function for you, having the subwoofer also set with a low pass filter will cause you to have a far steeper rolloff than you want on the sub. The specs on the speakers say 115 hz on the low end....so pretty much set the crossover as high as it will let you (you want to cross over before the speakers start rolling off if possible). If you find that this makes the subwoofer to noticeable and easy to locate play around with it a little bit, you can set the crossover lower if you have to.
monkish54 Audioholic General Dec 6, 2012 #66 Grador said: That is correct, you're going to let the receiver take care of that function for you, having the subwoofer also set with a low pass filter will cause you to have a far steeper rolloff than you want on the sub. The specs on the speakers say 115 hz on the low end....so pretty much set the crossover as high as it will let you (you want to cross over before the speakers start rolling off if possible). If you find that this makes the subwoofer to noticeable and easy to locate play around with it a little bit, you can set the crossover lower if you have to. Click to expand... What he said! As high as you can cross.
M mfontmt Audioholic Intern Dec 6, 2012 #67 Phase Error I am doing the Audyssey Calibration and I got a speaker phase error for my two fronts and center speakers. Funny thing is my wires are not crossed. They match up. Anybody ever encounter this? Could this be an error on Audysseys part or the speaker manufacturer?
monkish54 Audioholic General Dec 6, 2012 #68 mfontmt said: I am doing the Audyssey Calibration and I got a speaker phase error for my two fronts and center speakers. Funny thing is my wires are not crossed. They match up. Anybody ever encounter this? Could this be an error on Audysseys part or the speaker manufacturer? Click to expand... Try re-running audyssey.. If the problem persists, make sure the cables aren't wired incorrectly. Let us know..
M mfontmt Audioholic Intern Dec 7, 2012 #69 Tried again, same error. I checked wires. all match up on both sides...receiver and speaker.
monkish54 Audioholic General Dec 7, 2012 #70 mfontmt said: Tried again, same error. I checked wires. all match up on both sides...receiver and speaker. Click to expand... Weird. So it tests the fronts and center and immediately shows an error? https://audyssey.zendesk.com/entries/270385-speaker-polarity
M mfontmt Audioholic Intern Dec 7, 2012 #71 That link was very helpful. You are truly awesome. Let's see if I can make it through the rest.lol.
P Paul Jubick Enthusiast Dec 7, 2012 #72 so cheaper receive doesnt matter? the Dennon 1612 I can get new for $275. The Yamaha371bl for $169. you said my energy speakers are holding me back not receiver power. so will the Yamaha give me everything the Denon 1612 will? If in your opinion there is no difference< I will buy the Yamaha and save the money
G Grador Audioholic Field Marshall Dec 7, 2012 #73 Paul Jubick said: the Dennon 1612 I can get new for $275. The Yamaha371bl for $169. you said my energy speakers are holding me back not receiver power. so will the Yamaha give me everything the Denon 1612 will? If in your opinion there is no difference< I will buy the Yamaha and save the money Click to expand... I would never recommend getting the 371
zieglj01 Audioholic Spartan Dec 7, 2012 #74 Paul Jubick said: so will the Yamaha give me everything the Denon 1612 will? Click to expand... The answer is still the same - No
P Paul Jubick Enthusiast Dec 7, 2012 #75 thanks grador, Dennon it is One other thing, I have seen many posts here with people buying Energy Take Classic 5.1 speakers(like me) but many of them are using a different subwoofer. Why? the Energy's come with a sub. Does it not make the grade?
zieglj01 Audioholic Spartan Dec 7, 2012 #76 Paul Jubick said: One other thing, I have seen many posts here with people buying Energy Take Classic 5.1 speakers(like me) but many of them are using a different subwoofer. Why? the Energy's come with a sub. Does it not make the grade? Click to expand... There are better subs around.
