Suggestion for Subwoofer to pair with the new B&W 684 S2 home theater
crossedover
crossedover
Why the hell would you b bothered if Neverland had SVS sub's or not .if anyone wanted they could just import the damn thing . I give up on this bloody forum. Continue to sit behind ur ancient keyboard n diz people who really want to be educated
You seem to have it all under control. Good luck with your endeavor and new forum. FWIW you might find a few people from this bloody forum on other forums too :cool:
Also I dont think you would be importing any SVS subs with your stated budget
Most good quality subs are costly to ship overseas. SVS does make lighter ones such as the SB1000 and SB2000. Being sealed they tend to produce tighter bass that may also be punchy enough for you in a smaller room.
SVS SB-1000 - 300 Watt DSP Controlled, 12" Ultra Compact Sealed Subwoofer
Would help so much in order to avoid the stock B&W sub's
Is it because the B&W sub is over your budget?
Or because you've listened to the B&W sub and didn't like it?
Have you listened to any sub and liked it? Just to get us an idea of what you like.
If you have a smaller size room, most subwoofers would work just fine. I think any sub from SVS, HSU, Rythmik, NHT, would work well for your room.
http://www.amazon.com/NHT-B-10d-300-Watt-Powered-Subwoofer/dp/B0049SPA9K/ref=sr_1_1?ie=UTF8&qid=1412521329&sr=8-1&keywords=NHT+subwoofer
http://www.amazon.com/SVS-SB1000-12-inch-Powered-Subwoofer/dp/B00AF88C0M/ref=sr_1_2?ie=UTF8&qid=1412521361&sr=8-2&keywords=SVS+subwoofer
suniltgeorge
Amazon.com: NHT B-10d 300-Watt Powered Subwoofer with DSP (Piano Gloss Black, Single): Electronics
Thank you . this is all I needed. Well I went over to one of the distributors for SVS he have stopped dealing with them as they were having issues of defects or something and didn't recommend it . so thinking about it he suggested to stick to the b&w it self since we don't want a sub that mighy sound punchy but may die or have chances of . b&w being the reliable pick . so yah going with the b&w .. Got Lil scared hearing that
suniltgeorge
I din't say I would be searching for another forum to join dear friend :) anyways I got what I came here for :)
markw
Good. Don't go away mad, just go away. Thanks for the grey chicklit. I'll be waiting to pay ya back when you come back.
crossedover
crossedover
Yes. You did get what you came for. I've been curious enough to try to help but your 160 character responses have availed you zero respect from me. So who is you SVS dealer? Oh wait i call BS.
Yeah, if you can get the B&W sub locally, I would do that for sure. Hopefully it won't happen to you, but subwoofer amps can occasionally malfunction. If that happens, it may be a lot easier getting replacement amps through your local B&W dealer than overseas.
suniltgeorge
Yeah going most probably for the asw608 although I want to take the 610 . do you think it will make a big difference in such a small room ? Reminding you it is 12 by 11 ft fully with full acoustics walls and ceiling .
suniltgeorge
Thanks for being of so much help :) .. The dealer stopped SVS cause of issues of defective and faulty models and that it would affect his companies image who also dealers with systems such as steinway lyngdorf . do be frank I apologize for my lack of discriptive ness that you requiered
I suggest you email SVS to find out what the issues were. As far as I can tell SVS is known for their quality and reliability. I have 5 subs including 2 SVS ones, one is over 10 years old and gets used almost every day. If you email them about your situation they may let you buy direct from them. For the size of your room, and since you like punchy bass, you really can't go wrong with their sealed models such as the SB1000. You may also consider one of this VTF-2 MK4 Subwoofer that apparently can also be run in sealed mode. At 64 lbs it is more costly to ship but for $599 even with shipping you should still be able to stay within your budget.
suniltgeorge
Thank you
If not however I've selected b&w asw610 to go along with two 684 s2 . htm62 surrrounds as ds3 as bipoles powered by a reasonable amp I guess marantz 5008 . :)
suniltgeorge
Thank you
Oh I'm placeing the sub in the center under the centers .
suniltgeorge
I have a question for you guys how do you all know so much id say audiophile ? Its irrelevant to thread but yeah just curious cause I just want to appreciate good sound and know how to go about things too
Thank you
Priced at 500 UK pounds (not sure where you are), same as the SVS SB1000, seems like a great choice. If you have the 5008, be sure to run Audyssey if you want cleaner bass.
