Subwoofers for dedicated media room
mediabroom
I will have 7.2.4 set up for dedicated media room (15' wide, 19" deep, 10' ceiling), no windows, with Revel speakers
Front 3 R/L/C - Revel W990 x 3
Atmos Ceiling x 4 - Revel C583
Surround x4 - Revel W383
Sony Projector VPL -VW295ES
Which sub woofers to get? I guess in wall sub woofers will be too expensive?
Any recommendations with upcoming Thanks Giving Day/Black Friday/Cyber Monday Sale?
mazersteven
mazersteven
Whats the budget? In wall sounds like a pain to me, but if aesthetics and your budget accommodate it can be done.
Generally I'd look at SVS, Hsu, Power Sound Audio, Rythmik or Monolith..... perhaps a step up to Seaton, JTR and Funk.
mediabroom
How big of subwoofers would I need for 15' x 19' media room and which one will be good for the speakers that I have chosen so they are neither under or over board.
mazersteven
mazersteven
I posted and Link the ones you need for that size room
vader540is
vader540is
Dual Rythmik FV18
Dual Power Sound Audio TV1812
Dual JTR Cap2400
stalag2005
My neighbor already is not happy with my defiance x12. A deep sea 24 inch would shake my entire building
mediabroom
I am thinking either SVS SB-2000 vs PB-2000
mazersteven
mazersteven
Don't do the SB. With your size room it really wouldn't be that effective. I would do the PB2000 or the PC2000. And in my personal opinion I do believe with your size room you need two of them. Either one now and save for another or do two right away. That is why I recommended the PB3000 in the above link. You see a subwoofer need to fill the room volume and any attached rooms with large openings. Those all need to be taken into consideration when purchasing a subwoofer or else they will be ineffective. Yeah you'll hear a little bit but you will not be getting the effect of what they're capable of doing. And that would be wasting money
mediabroom
Tech guy at Crutchfield recommended SB-2000 and not PB-2000 for my room size (15' x 19'). He said PB-2000 will be overkill as I am buying dual subwoofers. He said SB-2000 has more clarity.
My room is closed dedicated media room with no windows and a single door.
