Subwoofer Eq Suggestions
Tomorrow
Tomorrow
Avaserfi,
I just received and installed my first GIK 244 panels this afternoon. I have a huge room that needs probably 10 times that many for perfection, but the change is noticeable with just the two panels behind my entertainment center (one straddling the corner). I think I'm gonna save up for a couple of corner tri-traps to add to the mix. (I may use them as surround stands! :))
I wish there was a quick way to A/B this setup...but no.... The panels made a significant difference in my YPAO eq setup, so I know they're doing something. And I think it's good, lol. ;)
mike c
mike c
I can't say for sure but I believe this is the same one used in Velodyne's SMS-1 EQ system.
it looks the same.
but I heard someone say that you can't use them interchangeably
mike c
mike c
tomorrow,
get somebody to run in with the panels right after you listen to your setup without! :)
Matt34
Matt34
Moderator
it looks the same.
I don't see why not, they come with a XLR connection which is all that is needed to hook it up to the SMS-1.
I'll find out in a couple days for sure, just ordered one.;)
mike c
mike c
must be the calibration of the mic or some correction thingy ...
what did you order? sms-1 or the ecm mic? or do you have both?
bpape
Glad things are working out for you. Let me know if you need any more help in working out the details.
Bryan
avaserfi
avaserfi
Tomorrow, I have decided you are a bad influence. You are making me want another sub! I was looking on craigslist and found an SVS 16-46CS that I might be able to pick up for 100 bucks. All I will need after that is a good plate amp and then build a nice housing for the amp and I might just have to wait on the BFD.
Who knows I would have to get the sub back from Texas though (visiting the folks next week)
Tomorrow
Tomorrow
A. You know you want another sub.
B. You may not need a BFD after getting the second sub.
C. That's a great price on the SVS.
D. I'm just a conduit of (ADD) AUDIO-DESIRE-DISEASE passed along by generations of Audioholics! :)
(subliminal suggestion....2 subs 2 subs 2 subs 2 subs 2 subs... )
avaserfi
avaserfi
HAH, I know I want them we will just see what happens when/if he replies to my email and how hard transporting the thing in my civic would be back to Iowa. It would be really cool especially since I already got WAF :).
avaserfi
avaserfi
Ewww...
Just got Room EQ Wizard up and running. Calibrated my sound card and installed the proper calibration for my SPL. The graph attatched is the results of the sweep after everything was ready and after I tried a few woofer locations too...
The untarnished graph:
With 1/3 octave smoothed:
Looks like I need to do some work on the room.
Tomorrow
Tomorrow
Dude, that graph looks like a worm crawled through some ink and then crossed the page. You're work is cut out for you! (But I know you'll enjoy the battle.):)
mike c
mike c
checklist to help you smooth that out short of getting a BFD or sms-1:
mess with the phase.
make sure you are not using the subwoofer crossover, leave the bass management to the receiver.
look for another location (after you've done the first two)
What cd is that? I have rives but it isn't quiet that inclusive.
Autosound 2000, Test CD #101. 209-465-3450. Not sure how current the number is but this will get you close.
They have other test discs too.
I think you will like that BFD and its flexibility on the frequency. You can select fractional frequency, as wide as you want or as narrow as a sheet of paper, all digital domain. It will take time as when you alter one frequency, it affects others in interesting ways and that is the nature or waves and closed spaces.
avaserfi
avaserfi
How'd you know I used a worm? Bet you didn't know I got him good and drunk first!
Thanks for the tips. I am using the receivers crossover and was actually planning on messing with the phase tonight :).
Thanks for the cd item I'll look into it. I am getting closer and closer to pulling the gun on the BFD I just want to do room treatments first.
mike c
mike c
I just have to clarify that the subwoofer crossover has to be set to bypass, or a crossover way way way higher than the crossover on the receiver.
avaserfi
avaserfi
It doesn't seem my woofer has the ability to bypass the crossover. Right now I have my woofers crossover set to its max setting (150) and the receiver is set to cross it over at 100 right now. Other than that the only things I can mess with are boundary gain compensation and phase both of which should help my current situation.
avaserfi
avaserfi
Forgot to ask my question and it won't let me edit. Am I in a safe range with my crossover than or is there something else I should look at?
bpape
It'll be less localizable if you set it at 80. It'll also put the non-removable xover more than double the xover in the receiver.
Bryan
