Subwoofer distance from back wall
  • Thread starter Thread starter toshigama
toshigama
2
0
1
32
How close to the back wall should a subwoofer be? I'm asking about sealed or front ported subwoofer not a rear ported subwoofer. Is it ideal to put it a close as possible against the back wall or is there a certain optimal distance that is recommended?
Depends how much boundary gain, port direction isn't very meaningful as subs more omniradiate. If you do put a port near a wall it's generally advised to distance it at least twice the diameter of the port. How did you determine the back wall is the best placement?
Might want to check out these articles
  • Like
Reactions: -Jim-
How close to the back wall should a subwoofer be? I'm asking about sealed or front ported subwoofer not a rear ported subwoofer. Is it ideal to put it a close as possible against the back wall or is there a certain optimal distance that is recommended tutuapp?
I got this,,...
