Stuck between 2 subs :(
Rowdy S13
Rowdy S13
j_garcia said:
I agree, not necessarily, but SVS and "poorly designed" aren't things I would put together regardless. The Plus driver has quite a bit more capability than the NSD, however it is in a sealed enclosure and it isn't a simple matter to overcome that.
Looking at the charts, the SB-12 gives up about 2-3dB across the range and drops off significantly earlier than the NSD around 22Hz, so I'd probably opt for the NSD (and it is $100 less).
This is EXACTLY why I ask these questions here :D This is a good (real) reason to get one over the other. I think after reading what you said here and thinking a lil, the NSD is the better option. Mostly because it will perform better in a large room, IF I end up in a large room. Plus I like DEEP bass, and the NSD seems like it would play deeper. Thanks again, Ill make a nice post as soon as I buy one.
Thanks again,
Sean
Rowdy S13
Rowdy S13
I just got an E-Mail back from SVS saying to get the PB12-NSD for the same reasons you listed. I cant tell you how much I aprciate the honest answer to my question from them. He gave me an honest answer and explained WHY thats the sub I should go with. Top notch coustomer service, and Im not even a coustomer yet!!! This just makes me want to order sooner :D
Sean
Sheep
Sheep
Might want to update your signature then eh?
SheepStar
Rowdy S13
Rowdy S13
SheepStar
Noted and UPDATED, as updated as updated can be. Now I just need to sell off some stuff to fund the second wave of my HT.
Sean
Rowdy S13
Rowdy S13
BTW Garcia, I just figured out how to add to youre rep, and I did so. Bumping you up to 2 chicklets. Thanks again.
Sean
mike c
mike c
lets get you a big fan club instead of that small one you got now ...
more chicklets for you ...
