I disconnected the cable wire from the wall and I still hear noise in the speakers. a crackle/pop every minute or so for the duration the system is on. Rembember it is not a constant hum or buzz but a split second pop that happens continously.
Here is what I know so far:
1. Subwoofer is not at fault. Totaly took it out of system and statice sound remained i.e uplugged a/c outlet and sub cable.
2. Cable TV is not the problem, disconnected it from wall jack, still crackle.
3 Have heard newer NAD receivers have this problem- the ones with the three prong plugs.
4. I really don't think it is R/F noise as it continues even when sub is disconnected.
I am thinking of upgrading the NAD Plug to a PS audio plug- I am convinced that it is line noise from dirty a/c outlet- though I am running through a Monster Stage 1 filter.
Out of ideas can anyone help me?
