Starter AV Receiver Advice
crazedwombats
Before I begin, I am a complete noob when it comes to AV stuff so thanks a bunch in advance.
I am looking for a starter AV receiver preferably $200-$300, but would go up to $400 if its really worth it. I already have a set of Polk Audio RM6750 5.1 speakers and would be looking to use it with my HDTV, PS3, and ipod. After looking at countless reviews, the following receivers caught my eye in the $200-$300 price range:
Yamaha RX-V363
Yamaha RX-V463
Sony STRDG720
Onkyo TX-SR506
Onkyo TX-SR576
and in the $300-$400 range:
Onkyo TX-SR606
but as I said before, unless you think its worth it I would rather not spend that much.
Let me know which one of these would be best suited for me for the money. I am completly open to other suggestions as well. Thanks!
Midcow2
Midcow2
some info
Yamaha RX-V363
Yamaha RX-V463
Sony STRDG720
Onkyo TX-SR506
Onkyo TX-SR576
Onkyo TX-SR606
Crazedwombats,
The Onkyo and Yamaha AVRs you have listed are very good. I am not familair with the Sony STRDG720.
If you are trying to future proof and want to conenct via HDMI 1.3 with upconversion ( changing composite and component formats to HDMI and also upconverting resolution and adding deep color) then the Onkyo TX-SR606 is a good choice. The other low model Onkyos don't have all of the upconversion features.
If you are just looking for a good 7.1 AVR music wise and not upconversion then any of the other Onkyos are good choices.
The Yamaha RX-V363 is great for 5.1 music and video without upconversion
just HDMI switching ( passes HDMI through without changing). If you want to get the upconversion capability with Yamaha you need to go up to at least the RX-V663 model.
Okay now best price I can find:
Yamaha RX-V363 = $158 http://www.fotoconnection.com/p86312-yamaha-rx-v363-51-channel-home-theater-receiver-black.html
Yamaha RX-V663 =$349 http://www.fotoconnection.com/p85676-yamaha-rx-v663-72-channel-digital-home-theater-receiver-black.html
Onkyo TX-SR506 = $206.32 http://www.amazon.com/gp/product/B0015M4G5C
Onkyo TX-SR606 =$299.99 http://www.consumerdepot.com/products.asp?id=TX-SR606D&referer=google
Good luck, hope this helps :)
ParadigmDawg
ParadigmDawg
Is fotoconnection an auth. dealer for Yamaha? They have the RXV3800 way cheaper than I have ever seen it.
budbrande
I have an Onkyo TX-SR605 in my bedroom system and it is a great little unit with decent features and good sound. If you are considering buying online may I suggest you check the online dealers rating at www.resellerratings.com before you buy. Especially if you are considering buying from some of the low ball dealers on the internet.
F
fox
And to think that just yesterday I saw the Yamaha RXV 663 priced at $525.00 at BB.
rnatalli
Both the Yammie 663 and Onkyo 606 can be had for $400 right now.
crazedwombats
Thanks for the responses! I'd definitely be up for getting the onkyo 606 or yamaha 663 if the price drops a little. Thanks for the links.
Is there any major features that the onkyo 606 has that the yamaha 663 doesn't and vice versa, or are they pretty comprable systems? Basically is there a better buy in this case or does it come down to user preference?
Also is the only major difference between the yamaha 463 and 363 the processing of audio over HDMI?
jcPanny
jcPanny
New receiver
Onkyo just came out with the new 606 model so you can find some deals on the 605 model with similar features and less HDMI inputs for <$400.
