bigpapa said:
No matter if axis is in front of you and behind you?
I'm not trying to dispute that it may sound better, I'm just trying to understand on a fundamental level.
The sound wave is generated at (essentially) the same point in space. Whether the tweeter is aimed (perfectly perpendicular to) behind your head, or in front of your head, it shouldn't matter as long as it's somewhere close to the axis of the tweeter.
This is stereo sound reproduction. There are NO standards; not for recording, mixing, mastering or playback. It's purely listener preference that defines what you should do.
Here is what happens with a
typical front-firing, direct radiator multi-way speaker with average polar response(which is not very good, btw) in a standard rectangular or square room with centered listening position with a symmetrical placement of speakers in relation to the walls, based on your toe in vs. toe out scenarios:
Toe in to fire directly at your ears or in front of head: the tweeter is highly directional above 8-10kHz, so is the midwoofer in it's upper range of 3-4kHz; the direct sound you hear is basicly the 0 degree polar response of the speaker. The power resonse(off axis total response) is rather poor for average speakers, and the toeing of the speaker exaggerated this problem at the extreme relative angle to the 1st wall reflections. This will tend to increase imaging focus; because you have reduced the 1st wall reflections and increased the treble balance as compared to being toed out.
Toe out to fire far behind head--basicly speakers are pointing straight or nearly straight: the tweeter and midrange are now radiating a more linear response to the 1st reflections, but the direct sound arrival is ramping down in treble response, because you are now considerably off axis(30-40 degrees probably) from the speakers. You hear a more even/linear 1st reflections, but the dircect arrival response is compromised. This will result in a better quality ambient/soundstage width effects on music containing such material because the treble response being reflected from the 1st reflection points on the walls is now higher in amplitude resulting in a stronger phantom sound source point and the sound will be less agressive sounding due to the reduction in treble energy off axis as compared to being toed in. The stronger phantom sound source points will tend to diffuse imaging, as will the reduction of the treble response due to the off axis reduced treble power.
There is no clear winner in toe in vs. toe out;
but in this particular case I would probably more likely toe in the speakers. If I found the treble to be too high in amplitude with toe in, I would put absorbers on the walls to reduce or remove the 1st reflections so that I could toe the speaker out as a form of treble adjustment without diffusing the imaging and overall clarity with the side reflections. But the treble balance difference due to toe out will reduce imaging somewhat.
This above is purely hypothetical; in reality I do not use average direct fire radiators. I was providing the above for reference only. I use speakers that have basicly a response approaching omnipolar; I use the unique 1st reflections from such a speaker to great adavantage, and I do not care if imaging is not as focused as is possible, because I place far more weight on realistic sound and ambience than I do on imaging. Tightly focused imaging is not something that will normally occur in real unamplified music circumstances unless you are sitting directly in front of the music source at a very close proximity.
-Chris
