darien87
Thanks for the info.AVRat said:darien,
The VR2s probably have a similar freq. response. The thing is that at -3dB, you are only getting 50% out of what you put in. At -6db, its only 25%. You may think you’re not using the VR2s full potential, but you are also not using your subs effectively either. Granted, you have some nice gear; well designed, sensitive speakers and robust subs – with the Denon 2805 only having a universal bass management, you also have to consider the freq. response of the other speakers as well. You may not hear much of a difference, but bass management is not just about improving sound quality, but also effective use of power. If you want to run the X-over at 60Hz, then do it. It’s your sytem. BTW, the 2805 has adjustable X-over settings, not fixed 80Hz as the sales guy said.
So I did some more research. I called Denon and you guys are indeed correct in that when you set the fronts to large, even with the crossover set at 60Hz, the fronts get a full range signal. So if you want the fronts to roll off at 60Hz, you have to set them to small.
I decided to test the response of my VR2's. According to Boston, they are rated at 40-20KHz. So I got an 80db baseline and used my Rives test CD to test lower than 40Hz. (I of course turned off my subs). The VR2's put out about 75db at 31Hz! I was pleasantly surprised. It seems Boston rates their speakers fairly conservatively. So I decided to leave the fronts set to small, but I dropped my crossover to 40Hz. I tested it out with the scene of the emergence of the first walker in War of the Worlds and it sounded great.
Now the only thing I'm worried about is the center channel and rears. Denon said that when you set the crossover frequency, EVERY speaker is crossed over at the same frequency. My center is rated down to 65Hz I believe, but my rears are just little bookshelf speakers. But I would assume that the movie mixers would know not to send bass frequencies to the center or surrounds. Just about everyone uses a fairly small speaker for center and surrounds don't they?
