Here you are actually incorrect... With most speakers this may be the case, but not when it comes to speakers with 1st order crossovers. They sound totally different at 50" as opposed to 10 feet, and this you may very easily hear.
Feel free to demonstrate this. A 1st order cross over has no significant differences that qualify it for a special distance vs. measurement function as compared to say, a 2nd order cross over. The difference in a 1st order crossover is simply the degree of phase angle modification(
in which, a transient-perfect phase response as allowed by a 1st order design has never been shown to be of any significant effect for musical playback [1]), the off axis response characteristics, as well as the degree of energy that breaches past the crossover point.
- Have you listened to the Swifts? I have not, so I can make no assumptions on the Swifts....
- Do you know they have colorations, or do you just assume that's the case because John Atkinson measures them incorrectly?
- Still it's very unfair to compare $900 speakers to 802d
- Have you seen the level of engineeing going into speakers like Kestrel2? They look like they cost 3 times more than what they do, and performance is stunning
I have seen no evidence demonstrating that Atkinson measured in such a way as to substantially alter the results. I am some what knowledgeable in the realm of loudspeaker engineering, and see no significant problem(s) in his measurement methods in respect to FR and waterfall/CSD plot acquisition.
My main point, You should not buy speakers based on reviews but what you really like, use a lot of time and listen to as many speakers as you can, then you will have a better backgrounder for making the correct choice.....
Much of my knowledge is in the area of perceptual research of this field - as such - I can determine many things related to audibility from a specific data set of sufficient detail that would not be possible for a normal hobbyist to determine. So while I understand that you and many other people like to conclude things with statements such as "just go listen", much of this field is quantifiable and audible results of many specific measured characteristics can be correlated to credible scientific research that cross-references known audibility thresholds and subjective results under blinded conditions of trained listeners vs. measured characteristics. The massive resonance seen in the waterfall is most certainly within the audibility thresholds as outlined in credible research
[2][3], as well as the poor off axis response
[4], demonstrated as being a negative influence on perceived sound quality by Toole(NRC/Harman) and Paisley(NRC/Mirage) in carefully controlled double-blinded testing scenarios of hundreds of subjects. In regards to the cabinet resonances - the amplitude measured is quite high - and considering the substantial cabinet wall surface area - it is not safe to presume that this is not going to be an audible contribution to the room, where as the 802D has levels of such low magnitude, that they barely register in the measurements.
-Chris
Foonotes
[1]On the Audibility of Midrange Phase Distortion in Audio Systems
Stanley P. Lipshitz, Mark Pocock and John Vanderkooy
JAES, Vol. 30, No. 9, September, 1982, Pages 580-595
[2]The Modification of Timbre by Resonances: Perception and Measurement
Floyd Toole, Sean Olive, JAES, Vol. 36, No. 3, 1988, March, pages 122-141
[3]Loudspeaker Distortions, Can We Hear Them?
P.A. Fryer, Hi-Fi News Rec. Rev., vol.22, pp. 51-56, 1977
[4]Loudspeaker Measurements and Their Relationship to Listener Preferences: Part 2
Floyd E. Toole
JAES, May, 1986, Vol. 34, pages 227-235
