Speaker cable elevators ?
lsiberian
lsiberian
The other reality is that speaker wire, as long as it is the correct AWG for the run and load, has one of the smallest influences on the sound of your system. There's nothing wrong with Monster cable besides the fact that it comes from Monster and costs too much. Speaker wires are not shielded.
Other than the fact they put plastic in the middle of the wire to make the copper appear to be the correct AWG.
gene
gene
Audioholics Master Chief
Administrator
MAN! What's next? Wire ESCALATORS?
Haha OMG that gave me a good laugh :D Introducing the new Wire Escalators, It continually varies the distance of your wires from the floor to reduce stray eddy currents by introducing a variable magnetic flux density which modulates out of phase with the audio signal. :rolleyes:
goodman
goodman
Gene may scoff, but the importance of elevating your cables for optimum auditory perfection cannot be overstated. I have experimented with a variety of cable elevators, including unobtanium-based dedicated elevators recommended by the sages at TAS that cost me a month's pay. However, the best results I have obtained are with ordinary styrofoam egg cartons. My first endeavor with egg cartons was revelatory. To my auditory delight, a new dimension was added to my listening pleasure. I reveled in the glorious rapture of the mellifluous tones emanating from my formerly pedestrian loudspeakers. And then, I wondered, "what if I placed eggs in the empty cartons?" The result was ethereal. Never had I heard such buttery lows and liquid highs. I gloried in the perfection of the golden tone. If you remain a skeptic, try it yourself. Eggs aren't just for breakfast anymore.
F
FirstReflection
AV Rant Co-Host
Of course cable elevators make an audible improvement...if you believe they do.
It's similar to the ability to walk on water. It's all about belief . The only reason nobody can scientifically prove the benefits of cable elevators is because people who follow the scientific method never believe hard enough.
:D
:D
No, it is because the people who design cable elevators can't walk on water no matter how hard they believe they can.
lsiberian
lsiberian
I walk on water everyday while I shower. :p I most certainly could walk across a river or small lake.
gene
gene
Administrator
do you prefer white or brown eggs? :D
According to what I have read it does help especially on carpet where static buildup can generate a magnetic field around the wires potentially degrading the sound. I recently moved my wires so that they sit on top of the baseboards along the walls which keeps them about 2-3" off the floor and I honestly can't say that I hear any difference in sound...but you may. It's worth trying for yourself as long as you don't spend any cash doing it. There are many DIY methods to elevate the wires. You can use upside down solo cups to try the experiment. Personally I just used clear scotch tape to attach them to the baseboards.
How would static build up on that stationary cable? I am under the impression that you would need some physical movement to create static electricity on anything. But, I have been known to be mistaken, from time to time.
I disagree. Having the speakers stapled to the ceiling is best. Then you get those amazing highs.
Well, then you only want to staple the tweeters up there, no? You wouldn't want the mids and bass so high, right? then you'd have no need for them. ;)
Hey, maybe that is the way to cut some cost:D
