Behave yourselves please, and try to state disagreements courteously. This especially apples to MacManNM, but others as well.
Back to the point: If I may use a lighthearted example, the elastic components of speaker drivers are like the elastic in your shorts: tight at first, followed after a brief (no pun intended) break-in (or stretch, for the shorts) by a long period of uniform performance within the tolerances for which they were designed, until at last a rapid deterioration takes place. Then your woofer stops woofing and your BVDs fall to your ankles. Hopefully the former occurs only once per several underwear life cycles!
Point being, the wear cycle of elastic materials does not follow a long, linear progression.
The need for
prolonged speaker break-in (and for specific break-in practices like playing pink noise, etc.) is indeed a myth. A few hours of your favorite music at normal listening levels is more than sufficient, if needed at all.
(My apologies to any here who do not wear underwear and had difficulty relating to the example...
