it is true
hi guys ,
this is wael ,
im a new member , depending on a lomg personal first hand experience with home theater equipment ( over 7 brands bought and replaced ) i tell you that the first time i heard about a break in period for my sound system was when i was putting a new 200 watts clarion 4 way speaker system in my car , when i was testing them after i installed them it didn`t rise to my expectations , but the technitian told me that i should give it some time and then see what happens especially for the bass part which was the important part you can always get extra tweeters but for the subs it is a lot harder , then it became a habit every time i bought a new sound system or a hometheater i always gave it time before passing on the final judgement , it realy takes time and if you take notice the first time you operate your sound system with it`s full capabilities and then wait say for 2 or 3 weeks you will notice the difference , that is way i don`t always go loud at the first few times i use the system i go slow specially with the sub i increase the bass gradually bcoz the material os the woofer at first is very let`s say tight but after a while of using and due to the movement of the woofer the material becomes alittle bit softer , so you will find an improvement of about 5 to 10 % , that is my experience it is not scientificaly proven or anything hope that it helps.
wael
