Sound issues with HK AVR 210
  • Thread starter Thread starter tigabalm
tigabalm
2
0
1
41
Hi guys, picked up a used HK AVR 210 and trying to set it up, but running into sound issues. Hooked up the two front channels and a dvd player, but not getting any sound through any of the input sources.
I did notice that when I adjust the volume I will get sound only WHILE turning the volume knob, but cuts back out once I stop turning the knob.
I tried the processor reset, but behavior persists. Any ideas would be greatly appreciated!
Thanks!
Thanks!
Try a hard reset and set it up again. What is the history of that unit? It sounds to me that it is likely terminal.
Is there a hard reset other than the Tone+FM button reset method?
Yea it’s gotta pretty iffy history. We got it from a family friend who got it new and used it for a few years. But after upgrading, the unit has been sitting for 10+ years.
Sounds like it might be a dirty volume pot, you might try an appropriate cleaner/solvent (like a De-Oxit product).
  • Like
Reactions: PENG
This is the instruction for a reset. You need to ignore Lovin today. That unit will have a digital volume control and not a potentiometer. It is a control that works in tandem with an IC chip and is nothing like to analog volume controls of old. It is worth three attempts of a hard reset. If that does not work it is the end of the road for that unit.
  • Like
Reactions: PENG and lovinthehd
Wasnt sure if this unit had one or not, but sounds like such behavior...
