Sony BDP-S350 and Yamaha RX-Z7
robmet1015
I currently have the sony bdp-s350 blueray player. My current receiver does not support TrueHD or DTS-HD MA.
I am thinking of purchasing the Yamaha RX-Z7 receiver and trying to verify if I will be able to receive TrueHD or DTS-HD MA from the Sony Blueray player.
I've read that the Sony Blueray can not decode TrueHD or DTS-HD MA on the device itself.
Does anyone know if I will be OK as the Yammy will be able to accept and decode TrueHD or DTS-HD MA ?
Adam
Adam
Hi. The Sony BDP-S350 can decode Dolby TrueHD, but it can't decode DTS-HD MA. It can pass both out as bitstream, though.
The Yamaha RX-Z7 can indeed decode Dolby TrueHD and DTS-HD MA, so it would work just fine with your blu-ray player. There are several less expensive receivers that can also decode those codecs, if you were interested.
Nomo
Nomo
The 350 will internally decode Dolby TrueHD but not DTS-MA. It will bitsteam both to a player that can decode.
With the Z7, the best option is to set the player to bitstream over HDMI and let the Z7 decode it. The Yamaha will likely have better decoders than the Sony player.
Nomo
Nomo
missed it by that much.:)
Adam
Adam
"Ask any racer, any real racer. It doesn't matter if you win by an inch or a mile; winning's winning." - Dom, The Fast and the Furious
:D J/K!
