Build Quality is great.
--Compared to other brands, I feel this TV is built a lot better and you do end up paying for it.
--Back metal housing, bezel, and over all build, feel and look "well-made." Just handling the panel itself, you can tell you do not have to be overly careful with it and that your money was well spent.
--Even the speaker that sits below the tv(or above) is well built and does not feel/look cheap at all.
Remote/User Interface
--I find the remote to be user-friendly. I like the design and the color. The buttons are somewhat small and they also do not light up, this may be a problem to some. its a "compact" remote, that will fit most hands.
--Navigating through the menus, or making changes/adjustments is very easy.
--I love how you can do a "before and after" when making picture adjustments. Very useful.
Sound
The speaker is clear and works well. It has enough volume to fill up most rooms and does not break up easily. Its not a replacement for a HT setup, but its great for what it is. For all the bass heads, yes it does lack bass.
No Glare?I really thought I would get a lot more glare than I did(thank god)..Basically the sunlight is beaming maybe less than a foot away from where we have the TV, and no reflections at all. I think naturally, in a darker room, any tv will look "better" as oppose to being in a brighter, well lit room.
--Not sure what buzzing people were talking about, but I cant hear any buzzing unless i am directly in back of the set and listening..No noise really, what so ever..tg
Out of the box Viewing..Using D-Nice Burn-in settings; Movie mode
--First impressions...wow....Great level of color, detail and just overall fluid motion. The tv just works, and it works very well.
-I have watched some material using PS3, external HD via USB2.0(all mp4 files), and comcast cable via hdmi...All look amazing, especially planet earth, ultraviolet, 300 and some more stuff..
-Blacks, Whites and overall color is great. I can tell it has a little red push, but I will take care of that after the break-in..
So far im happy with my purchase. Ill post some pics asap, if you guys have any request let me know.
