Those are a pretty cool gift to receive. They are also from deep down the audiophile rabbit hole, at least as far as how most folks use them, e.g. with high source impedance amps and such. There is a bit of method to that madness, as an amp with no damping factor to speak of will result in more bass than a typical, near zero output impedance amp would. Examples would be some of the First Watt offerings or some of the more crude tube amp designs. Either of those would be an option if you were to DIY.
If you plan on pairing them with a more normative amp (one with near zero output impedance), I would check to see if the speakers have any sort of BSC (baffle step compensation) in the form of some sort of passive network bits. You may have to pull the driver to determine this. If there is none, as is likely the case, as audionuts don't approve of passive bits in the signal path, you should consider it. TLS can probably give you some specific ideas as to what exact approach to use here. It will make the speakers sound better, IMO.
Also, you mentioned some Salks or equivalent down the road. Those will require more proper amplification, where the Fostex can be driven with just about anything due to their high sensitivity and easy load. You could very well keep the amp limited to "inexpensive and sufficient" for now (everything mentioned upthread so far would qualify, but I would suggest those with tone controls).
