Thanks Billy! What made you go to the XS30 vs the subwoofer you had built? I'm still fine with my Velo right now, it has a massive amount of output for it's size. I will be probably upgrading my fronts in the nearish future (moving back into my parents RENOVATED basement to save up for a house). I want something good for movies, but I just can't decide. Energy RC30s pop up on CL all the time, and Paradigm has always been a brand I wanted to like, if that makes sense. I'll need to see what the system is like when it's in that room. It'll have full proper in wall wiring and some RBH in ceiling surrounds that I was given.
SheepStar
Just want to change things up...the XS30 gives me that added extension down low...I usually don't exceed reference playback beyond peak levels...so...I always had a ton of headroom at my disposal...I just felt the my old sub dropped off suddenly ~18hz....the PSA is able to give me more of what I wanted and substantially more "mid bass" thump.
Now...sure...the old sub really did a great job in that capacity (about as good as it gets for a 12" ported) but you can only ask so much from that driver...even one as robust and linear as the AV12x...with the likely room gain and being a sealed unit I suspect achieving 14-15 with the XS30 was not impossible.
If...I could of had one wish....having bought the XS30...it would have asked for it to be a little more articulate with music and able to produce certain notes with better response and literally zero overhang like the SB13U displayed.
My understanding with the newer modified OEM version LAB15 drivers PSA is now using...it would likely add a wee bit more in hz/spl and making an already good product... even better...IMO. Heck...I might need to re-borrow that SB13 again....down the road....
Simply put...if the numbers are accurate & according to PSA....which I have no reason to doubt..this makes the XS30se a poorer mans version of the SubM. That SubM would have cost me >3k cdn to my door. The XS30 was a "bridge" or stop-gap...at least for the time-being and with the new units it now makes me a lot happier... even for the long haul...
Cheers...Bill
Ps: I'll be heading to Ohio in early July & stopping by PSA facility in Mineral Ridge. I'm going to demo a set of Traix's & with some luck, sample their new line of HT speakers coming out in the non to distant future....I'll report back once we return home but you can be certain...I won't be returning with any more subs...my missus would kill me & she is on this trip...
