Sharpness setting in 55" Vizio E series?
Y
yepimonfire
Ratings
430 13 5
#1
I've read most reviewers (rtings, for example) recommend setting it to 0 in most manufacturers TVs, including Vizio. The original "calibrated" setting (20) looks okay on 4k content but not great, and way too soft on upscaled content.
Using a test pattern, it didn't show any unnatural edge enhancement at 20 but a little bit above that level. Setting it to 0 looks awful, and 20 is still a bit softer than I'd like. At 25, it looks a lot more true to life, especially on upscaled material (or even 30 when upscaling from 720p). Is it generally a bad idea to increase the sharpness above the "calibrated" level? It seems to me real life looks sharper than the TV does at 0 or 20.
Sent from my LM-X210(G) using Tapatalk
Ratings
7,276 8 26
#2
Calibrated is exactly that, the reference point. Just like audio calibration, you are free to tweak to your own preference.
pewternhrata
Ratings
174 2
#4
Try readjusting the contrast after sharpness is set at 0. I would also turn any 'edge enhancement' settings off or low. While your at it, turn off basically every 'enhancement' setting. If you wanna see how they affect the picture, try them after the TV is calibrated.
Ratings
7,276 8 26
#5
All of the settings affect the others. I normally turn sharpness (and edge enhancement, motion enhancement, noise reduction, etc...) settings down most of the way, if not off; depends on the display, BEFORE adjusting the other settings.
