Serious quesion about artificial 5.1 setup
Zerohero
Zerohero
I have a regular 2 channel reciever that I have 4 speakers hooked up to. 2 on the left, and 2 on the right. Now I was experiementing with this the other day, but I think I created me an artificial center speaker. I added a 5th speaker to the mix, and hooked up the left negative channel with the right positive channel, and now that 1 speaker recieves signals from both the left, and right channel.
So theoretically, did I not just create a artificial center speaker , 2 fronts, and 2 rear? All I would need is a sub connected in a similar way , and I would have an artificial 5.1 surround sound.:cool:
markw
Welcome to the 70's
No. All you've done is create a "difference" speaker. In phase left and right signals cancel out and only the out of phase information is reproduced. This is a quasi multichannel effect that was used in the early 70's. One version was offered by Dynaco. You would probably benefit from padding the output down as it most likely is louder then the other two speakers.
So, while it's neither a right or left channel, it's not a "real" channel in the sense that what comes out of it can be predicted.
Zerohero
Zerohero
Ah I see, thanks alot. I thought I messed around , and stumbled upon something.
Zerohero
Zerohero
So I'd probably be better off adding a 3rd pair of speakers and basically putting those two up front, then use the other 2 pairs as suround side, and suround rear correct? So I can have a simi 2.1 suround setup.
markw
Personally, I don't see what that speaker adds but be careful simply adding speakers in a serendipity fashion not recommended by the manufacturer. Doing so just might reward you with the ultimate in high tech silence and perhaps a whiff of smoke.
Actually, I'm surprised nothing happened when you did the first one.
Zerohero
Zerohero
I've been messing around doing this for a while, since my HS days. Never had a blow out. I just experiment to get the best out of what I have at the moment.
Z
zumbo
:D :eek: :D :eek: ROTFLMAO
Z
zumbo
If a 2-channel receiver is what you have, then 2 speakers will be the best sound.;)
Zerohero
Zerohero
Well I added extra two because I gotta have some bass...
Zerohero
Zerohero
zumbo said:
What four speakers are you using?
Well I'm using two KLH's that have an impedence of 8ohms, and two AKAI (That produce the most base, but not the best pure sound as KLH), that have an indpedence of 6ohms.
Z
zumbo
There will be a sizzle, probably followed by a little smoke.:eek:
Zerohero
Zerohero
Well I haven't recieved any problems for a VERY LONG time doing this ( 2 years). My reciever is 250 watts btw.
Z
zumbo
This receiver?
Or this one?
http://students.washington.edu/ezw/AuctionItems/(S)Kenwood_KRV8540.html
You stated you just purchased the Pioneer in Jan, and that it was your first receiver. Then, you stated you just purchased the unit above. The unit you claim you just purchased is not 2-channel. The Pioneer is certainly not 250watts. So, please show me this receiver you are using. I am lost. Here is your last thread: http://forums.audioholics.com/forums/showthread.php?t=18481
Let's keep the BS to a minimum.
Zerohero
Zerohero
zumbo said:
This receiver?
Or this one?
No, that reciever still has not came in yet, I'm still currently using my old one. And that NEW 5.1 reciever I didn't get it like I thought I was :-/
So I'm currently using this one - http://videogamecollectors.com/albums/Zerohero-s/Picture_022.sized.jpg
Untile the one you posted above (Not the 5.1 reciever) comes in the mail.
The "BS" comment was a little rude, and out of place. I was being serious, besides, why would I have to lie on a message board especially when I only have 19 posts?
Z
zumbo
Sorry about the rude part.:eek: I just didn't see a unit that puts out 250watts. And I don't see one from that picture. I would not recommend a pro-logic receiver. But, if you really want one, I still have that Onkyo. I have the manual. If you want, I can dig up some information on it.:confused:
Zerohero
Zerohero
No hard feelings, how much you sellin it for again?
