oh! and ill be within fairrrly close proximity for the most part but I do want my system to be able to bang!
Okay. The reason for this is that some speakers, like the EMP E55Tis for example, can certainly get loud, but require a bit more distance for the multiple driver arrays to sum correctly.
I listen to music quite loud regularly. And is there any other way to get around buying an expensive receiver? probably not
haha
Full on surround systems will have the following features before the speakers:
HDMI inputs and outputs.
Automatic speaker setup (levels / delay)
High voltage preamplifier outputs to drive powered speakers or external amplifiers
Decent power amplifier
Bass management
Dollar for dollar, a good surround receiver covers all of these bases and also allows you to build your system upwards. If you pounce on this:
Marantz SR5004 90w X 7ch Home Theater Surround Receiver | Accessories4less
it could cover those criteria well. It is HDMI 1.3 however, so if you want to watch your movies in 3D, your 3D bluray player should have a separate HDMI output for audio and video, as HDMI 1.3 won't carry the 3D signal.
Realistically, most of us here could easily spend your whole budget on a receiver alone - and consider it an overall unimportant part of the system. So it's definitely tricky.
Overall, I don't think you should get a receiver on your budget. I like matt's idea of large powered studio monitors, though integrating a sub would not be easy. if you ever wish to add a receiver, they could be driven from preamplifier outputs.
I would however not personally go for the KRKs due to their measurement:
these JBLs:
JBL LSR2328P | Sweetwater.com
Seem a bit better to me:
Now listening to music loud is its own issue. Direct radiating tweeters don't normally play well loud. thin, tall, light, mildly braced tower speaker enclosures can have certain resonances which muddy up the sound at high SPLs. 3-way speakers flat out cost more. It's pick your poison with a small budget, even for stereo. I think the 8" midwoofers on the JBL LSRs should do pretty well from an output perspective. It probably won't tear your house down with earthquake bass, but for that you'd need to quadruple your budget and spend it on subwoofers alone.
