Pat, here is an
opamp calculator.
Go to topology and bring down the menu and click on non-inverting. This gives you an opamp with two to one gain, and up to 4.5 volts out which should be plenty.
Vin is the inline voltage of 5 volts DC, this is pretty usual for opamp chips. You would need a dual linear audio opamp chip for stereo. These are plentiful and cheap, usually around 50 cents. To power it I would get a wall wart of about 8 to 12 volts and then get a 5 volt output regulator IC chip, and put a 5 volt 25 mfd cap across the output and ground.
Vref is your input and Vout the output. The downward facing triangle is ground.
That circuit will do what you want.
