Samsung 46A650 and YCC
Affejunge
So, I have been content with my system for about 3 months, which means, since there is nothing wrong with it, it is time to screw around with the settings.. :D
I noticed my oppo 980 was set to output RGB 4:4:4. I had calibrated my tv using the settings given by C-net as a start.
http://help.cnet.com/9602-12576_39-0.html?messageID=2510694
I always found it interesting, that Audioholics own pro-review of the A750 said no adjustment needed to be made. Hmmmm.
So for grins, I set my Oppo to YCC 4:4:4. Look kinda washed out and not so hot, I was getting ready to set it back...then I though, "Well, let's really break this."
So on my Sammy, I reset to the default settings... BAM! The color almost popped off the screen. It looked awesome (to be clear it was not quite default, I turned off 120hz (hate that for anything but Pixar movies) and turned on Film Mode) I still need to tweak it as the colors are slightly more saturated than I would like and there is slight crushing of the blacks. But I would say overall to picture is much richer.
So is it the YCC vs RGB or just that I should have left the defaults all along? (That said, switching to RGB now doesn't look quite as 'rich', but that could be subjective)
On another note, I send a 480i signal to the Sammy over HDMI, it does a much better job at upscaling/deinterlacing than the 980. Anyone know how it would compare to the 983?
Affejunge
Don't ever doubt us again! lol
You're likely clipping black and white levels with it at RGB. Check this out:
http://www.audioholics.com/tweaks/calibrate-your-system/hdmi-black-levels-xvycc-rgb
What a great read! I new that mpeg was encoded in YCC, I just never understood how it all broke down. Never ceases o amaze me what I can learn here.
Here is another question: The Oppo 980 can output RGB 4:4:4, YCC 4:2:2, or YCC 4:4:4. Which should be the correct setting? It seems YCC 4:2:2 since that is closer to what mpeg is encoded in. With YCC 4:4:4 is the player doing more sampling or is it doing nothing? (Just passing the 4:2:0 signal through)
