I need to dust off my old Oppo since I used the model number in my tag.
T Trebdp83 Audioholic Ninja Nov 15, 2020 #141 I need to dust off my old Oppo since I used the model number in my tag.
lovinthehd Audioholic Jedi Nov 15, 2020 #142 Trebdp83 said: I need to dust off my old Oppo since I used the model number in my tag. Click to expand... Got one that can rip the multich sacds? I wish mine still had that capability....
T Trebdp83 Audioholic Ninja Nov 15, 2020 #143 Never tried ripping them. Now you’ve gone and given me something else to try and do. Don’t know if I should thank you or blame you.
afterlife2 Audioholic Warlord Nov 15, 2020 #144 Thanks fellas got everything coming in better after your suggestions. Seem like Denon supports DSD. New settings:
lovinthehd Audioholic Jedi Nov 15, 2020 #145 afterlife2 said: Thanks fellas got everything coming in better after your suggestions. New settings: View attachment 41683View attachment 41684View attachment 41685 Click to expand... You're using the optical/coax output?
afterlife2 Audioholic Warlord Nov 15, 2020 #146 lovinthehd said: You're using the optical/coax output? Click to expand... No. Turn it off? Seems like it makes no difference turning it off.
lovinthehd Audioholic Jedi Nov 15, 2020 #147 afterlife2 said: No. Turn it off? Seems like it makes no difference turning it off. Click to expand... You changed the output for it so wondered....
afterlife2 Audioholic Warlord Nov 15, 2020 #149 Trebdp83 said: Play anything yet? Click to expand... Beck Sea Change SACD
afterlife2 Audioholic Warlord Nov 15, 2020 #151 Trebdp83 said: Sound good? Click to expand... Surround is great, but Becks voice on it is weird. First time listening though. Peeps rave about this sacd
T Trebdp83 Audioholic Ninja Nov 15, 2020 #152 Did they put the vocal in the center or spread it out across the fronts?
afterlife2 Audioholic Warlord Nov 15, 2020 #153 Trebdp83 said: Did they put the vocal in the center or spread it out across the fronts? Click to expand... Across the front. First thing i checked and surrounds have a dimension to them. It’s pretty cool.
