Recommend home theatre audio to pair with ps3 and Sony xbr4 tv????
sholling
sholling
$1500 is about the entry point to good quality so I'll toss out few options. But since all I have to go by is a price and a TV the suggestions will need to be refined. For example without room size it's impossible to size a subwoofer. Second just based on TV and PS3 I'm assuming it's for movies more than music. Third I'm guessing your XBR4 does not support 3D.
Almost all in one solutions:
Option 1
A SVSounds SBS-2 Deluxe 5.1 speaker system ($1150) should do fine in a medium sized room. Upgrading the surrounds to the SSS-2 surround speakers ($150 option) would be a nice touch but takes you over budget.
Option 2
Hsu Research's Enthusiast 2 speaker package should do fine in a medium sized room but is slightly over budget at $1250 and up depending on finish.
The really good put it together yourself medium-large room option:
2x Infinity Primus P362 towers ($400/pr)
1x Infinity Primus PC350 center ($200)
2x Infinity Primus P152 boonkshelves for use as surrounds ($150/pr)
That's $750 of your budget. For the subwoofer the best thing to do is contact Elemental Designs, Hsu Research, and SVSound and have them size a sub to your room. If necessary you can hold off on the surrounds and use that money to buy enough subwoofer.
Receiver
I don't believe your TV supports 3D so last year's Onkyo TX-SR707 receiver would be a great match to any of the above. If you're in the US you can buy factory refurbished for $400 from Accessories For Less - however if I guessed wrong about 3D and you want 3D support then you'll want the newer TX-NR708 at about 50% more money.
Cables
Cables and speaker wire are cheap at Monoprice.com.
L
Leugim80
Hey thanks for info. Right now it will go in a open
Basement. It's not 3d. How about something with
Wireless rear speakers???
sholling
sholling
I don't know of any decent wireless surrounds. Perhaps someone else has an idea.
sholling
sholling
Oh and just an FYI, in a 5.1 system the surrounds go to your left and right, not on the back wall. Maybe that will make it easier to figure out how to use wired speakers.
jostenmeat
Think about this for a moment. Are wireless speakers really wireless? No, because they have to be plugged in to an electrical outlet. ;)
Also check out PSB and Ascend at your budget.
